![Photo](https://secure.gravatar.com/avatar/a3207c96a752ee0ec026f7707e306faa?s=100&d=https%3A%2F%2Fwww.theminiforum.co.uk%2Fforums%2Fpublic%2Fstyle_images%2Ftmf%2Fprofile%2Fdefault_large.png)
10” Steel Wheel Hub Cover
Posted 28 May 2023 - 10:24 AM
Posted 28 May 2023 - 10:26 AM
Thanks!
Posted 28 May 2023 - 10:54 AM
A piece of 1.6mm plate 150mm long x 22mm wide with the last 11mm of one end bend at 90 degrees. and the other end rounded. all corners smoothed off. That was the standard removal tool used by hooking under the cap and pulling. if it didn't move levering sideways tended to work though it could scratch the paint of the wheel.
Source, just went and measured the one I still have tucked away in my toolbox.
Posted 28 May 2023 - 11:24 AM
I’ll see if there are tools online that are hopefully similar to what you described.
Thanks again!
Posted 28 May 2023 - 01:37 PM
Either drive over a bump or just whack a screwdriver or something in the side to pop them off.
Posted 28 May 2023 - 02:59 PM
You could try something like this with a cloth behind it so it doesn't scratch the paint
https://www.ebay.co....:Bk9SR6ic6K2MYg
Posted 28 May 2023 - 04:01 PM
Posted 29 May 2023 - 10:33 AM
Used to remove car trim too.
Posted 29 May 2023 - 11:28 AM
