I have always used the rule of nine when adjusting the valves on my 998cc but I know of people who do not use this method. Can you adjust them some other way? Just curious :)
Rule Of 9
Posted 28 May 2023 - 03:27 PM
Posted 28 May 2023 - 04:15 PM
Posted 28 May 2023 - 04:49 PM
Ie adjust valve 1 &2 while 7&8 are rocking,
Adjust valves 3&4 while 5&6 rocking etc,
I use the rule of 9 as it’s what I am used to.
Ac
Edited by ACDodd, 28 May 2023 - 04:49 PM.
Posted 28 May 2023 - 05:16 PM
Which ever one’s down,adj mirror image ,
Piece of piss,
Do mine in 10 mins max
Edited by Tones61, 28 May 2023 - 06:18 PM.
Posted 28 May 2023 - 05:17 PM
The "FIGURE 9" method has been the accepted method of setting the tappets for ever, it saves making too many turns of the engine, but you can set the by this method, if you have nothing better to do like watching paint dry etc.
Turning the engine in the normal running direction set the valve you want to adjust fully open, then turn the engine one complete turn, this puts the valvetrain fully on the dwell sweep of the camshaft and the adjustment can be made.
Posted 28 May 2023 - 05:42 PM
You can adjust via the ‘use the rocking principle’
Ac
This is the way I adjust mine
Posted 29 May 2023 - 05:08 AM
ive always gone with the rule of 9 too. Its just easy and methodical.
