Any help gratefully received! We have a 1997 MPI Cooper with no spark. It was working fine before restoration but now doesn't work for some reason. We've replaced crank sensor and coil pack with no joy.
What readings should I be getting on the wiring plug that plugs into the coil pack, at present we are getting 12.5 volts but when its cranked it goes to zero? not sure if this is right!
Starting to lose the will to live with it, any help would be amazing! Thanks for reading
