Tie Rod Ball Joint Nut Seized
Best Answer Coalhod , 04 July 2023 - 03:40 PM
You might try placing a piece of wood or similar soft item on a floor jack and then applying pressure from the bottom of the tie rod ball joint. You don't need a lot of pressure, just enough to break the nut loose.
Go to the full post#1
Posted 04 July 2023 - 03:23 PM
It’s seized onto the thread / bolt. Everything is just turning together.
Cheers.
Posted 04 July 2023 - 03:40 PM Best Answer
Posted 04 July 2023 - 03:49 PM
Posted 04 July 2023 - 04:00 PM
Nut splitter and a 3/8 electric impact, be off in seconds.
But everything is turning
Posted 04 July 2023 - 04:15 PM
joint splitter, it's not hard. New nyloc as per any service manual.
Posted 04 July 2023 - 06:32 PM
Any suggestions on undoing the tie rod ball joint nut please.
Cheers.
Tie rod ball joint?
you mean the ball joint nut?
top or bottom on on the hub?
Posted 04 July 2023 - 07:16 PM
Cheers.Tie rod ball joint?
The Tie rod ball joint. The nut on the top just turns with the bolt/thread. Ive attached a photo the bits pointed to with the green lines turn together, how do i grip the thread to release the nut. ?
Edited by Stiglookalike, 04 July 2023 - 07:17 PM.
Posted 04 July 2023 - 07:23 PM
Posted 04 July 2023 - 07:36 PM
It might be that even if you get the nut off a new one may not tighten without spinning the pin. Just cut the old nut off and buy a complete new track rod end, fixed.
Posted 04 July 2023 - 07:52 PM
Posted 04 July 2023 - 08:03 PM
Thank you for everyones help. Yep this is what worked, put a jack under it to put pressure on the force the joint together. Came off fairly easy after that.
Posted 04 July 2023 - 08:42 PM
Cool. And we tend to call that the track rod end as it is attached to the rack track rod. The Tie bar is the forward facing bar that bolts to the lower suspension arm.
