Wiring Diagram
Best Answer stuart bowes , 06 July 2023 - 08:39 AM
in fairness not one of them mentions the mayfair, I had this same problem
If I recall correctly this is the closest one I found which suited my loom when I was checking through it
https://www.theminif...ttach_id=193855
still though it pays to carry out full continuity testing and tick things off the chart one at a time, you might find some minor corrections to pencil in and also it's worth doing the testing anyway to check faults.  check with the switches connected if you can because sometimes you find issues with them, like my headlight switch went in the bin and my indicator stalk module needs replacing
while its out you can consider modifications like adding relays and new wiring for the headlights, deleting the dim/dip relay and resistor (if fitted, top right of diagram in dotted box) and so on
Go to the full post
13 replies to this topic
#1 Propshaft
Propshaft
  • 160 posts
Posted 06 July 2023 - 07:13 AM
I have a 92 mini Mayfair on a single carb has anyone got a wiring diagram for this model I bought the car in bits with the loom taken out and nothing tagged so a diagram would be really useful
#2 Spider
  • 15,229 posts
Posted 06 July 2023 - 07:29 AM
At the top of this very section you'll find just about every wiring diagram;-
https://www.theminif...agrams-redrawn/
#3 stuart bowes
stuart bowes
  • 2,287 posts
Posted 06 July 2023 - 08:39 AM   Best Answer
Edited by stuart bowes, 06 July 2023 - 08:42 AM.
#4 cal844
cal844
  • 9,667 posts
  • Local Club: TFMOC
Posted 06 July 2023 - 11:07 AM
I use the 89 onwards diagram. There's 2 fuses and an extra relay that are different from diagram 18 in Haynes
#5 Propshaft
Propshaft
  • 160 posts
Posted 07 July 2023 - 06:44 AM
Hi Stuart don’t seem to be able to get the link you posted I can get onto the first link sent by one carb or two but can’t down load any which one of them is the one you used and how can I down load them
#6 stuart bowes
stuart bowes
  • 2,287 posts
Posted 07 July 2023 - 09:41 AM
you should be able to right click on my link and chose 'save link as' which should bring up a save-as box and you put it where you want ?  pdf file
it's possible your browser hasn't got the PDF reading ability ?
if that saves and then just shows up as a white square unrecognised file you need to install adobe acrobat it is free
when looking at the original list it is this one I've highlighted in bold
From Rover repair manual AKM 6353 1976 - 1989
Attached File  ROVER MINI WIRING DIAGRAM MINI 850 SALOON VAN AND PICK-UP 1976 ON.PDF   125.67K   232 downloads
Attached File  ROVER MINI WIRING DIAGRAM MINI 1000 SALOON - MINI SPECIAL 1976 ON - PAGE 86-5.PDF   130.15K   717 downloads
Attached File  ROVER MINI WIRING DIAGRAM MINI CLUBMAN, ESATE AND 1275GT 1976-ON PAGE 86-7.PDF   134.73K   132 downloads
Attached File  ROVER MINI WIRING DIAGRAM MINI SPECIAL - 1977-78 PAGE 86-9.PDF   132.34K   106 downloads
Attached File  ROVER MINI WIRING DIAGRAM MINI 1000 CANADA - 1977 ON PAGE 86-11.PDF   140.69K   79 downloads
Attached File  ROVER MINI WIRING DIAGRAM MINI SPECIAL - 1979 PAGE 86-13.PDF   138.44K   168 downloads
Attached File  ROVER MINI WIRING DIAGRAM SINGLE INSTRUMENT PACK 1984-ON PAGE 86-34.PDF   124.84K   451 downloads
Attached File  ROVER MINI WIRING DIAGRAM MULTI INSTRUMENT PACK 1984-ON PAGE 86-36.PDF   135.19K   720 downloads
>>>>>>  Attached File  ROVER MINI WIRING DIAGRAM 1988-ON - PAGE 86-49.PDF   168.13K   913 downloads <<<<<
Attached File  ROVER MINI TWIN GAUGE INSTRUMENT PACK WITH INTEGRAL VOLTAGE STABILISER - PAGE 86-50.PDF   165.36K   245 downloads
Attached File  ROVER MINI TRIPLE GAUGE INSTRUMENT PACK WITH INTEGRAL VOLTAGE STABILISER - PAGE 86-50.PDF   167.65K   513 downloads
Attached File  ROVER MINI WIRING DIAGRAM TURBO MODEL - PAGE 86-53.PDF   98.95K   89 downlo
Edited by stuart bowes, 07 July 2023 - 09:42 AM.
#7 Propshaft
Propshaft
  • 160 posts
Posted 07 July 2023 - 02:31 PM
Hi thanks for the reply I only have an I phone and I pad I will see if I can get abode acrobat just tried it’s £6-99 a month so don’t think I will bother with that thanks for your help
Edited by Propshaft, 07 July 2023 - 02:37 PM.
#8 cal844
cal844
  • 9,667 posts
  • Local Club: TFMOC
Posted 07 July 2023 - 08:55 PM
View this thread on a PC, the file should download automatically
#9 stuart bowes
stuart bowes
  • 2,287 posts
Posted 07 July 2023 - 09:01 PM
is there not a free or cheaper version, try searching for 'pdf viewer' instead of specifying adobe acrobat
normally acrobat is a free thing though quite why they would need to you pay that much per month is crazy, I wonder if that;s an 'pro' version or something where you can edit and create pdf's instead of just viewing them
Edited by stuart bowes, 07 July 2023 - 09:02 PM.
#10 gazza82
gazza82
  • 3,026 posts
  • Local Club: TMF+
Posted 08 July 2023 - 08:17 AM
Propshaft,
Just get Adobe Reader .. free versions for all platforms ..
Been using it since the year dot ....
https://get.adobe.com/uk/reader/
Edited by gazza82, 08 July 2023 - 08:18 AM.
#11 Propshaft
Propshaft
  • 160 posts
Posted 09 July 2023 - 07:40 AM
Hi I have got the free version of abode reader and cancelled the pay one just got to work out how to use it you have probably now realised I am not good with modern technology
#12 gazza82
gazza82
  • 3,026 posts
  • Local Club: TMF+
Posted 09 July 2023 - 08:35 PM
What are you using it on?
#13 Propshaft
Propshaft
  • 160 posts
Posted 11 July 2023 - 07:09 AM
All sorted know thank you all for your input
#14 humph
humph
    How bad can it Be?
  • 1,113 posts
Posted 11 July 2023 - 09:39 AM
This is interesting.  I have regularly accessed these diagrams from my iphone & ipad during my rebuild, and never had any issues.  They just open in safari, adobe not needed. That said I also have adobe installed on both with no payments made.
