So I attached as advised and works fine and more importantly I needed to adjust the timing from original - 8/1000 at idle to 10/1000 at idle - and from 26/4000 to 24/4000 performs much better and will tweak some more now that I know how to set timing
Vmax Sc - 1293 - Removed Vacuum Advance - Runs Better!
postve
, Jul 08 2023 01:24 AM
Best Answer NZMini1275 , 13 July 2023 - 11:06 AM
For a std dizzy the vacuum advance connects to the top brass connector and the boost gauge connects to the connector on the rear
I run a 123 tune dizzy and that connects to the boost fitting as it has a boost retard function
Without vacuum advance your off boost performance would be lacking. Remember that off boost you have a very low compression engine
Go to the full post
15 replies to this topic
