Adding A Rh Fuel Tank?
Posted 08 July 2023 - 02:08 PM
Posted 08 July 2023 - 03:29 PM
I have made a lefthand template in the past and reversed it to the right side with no major alignment issues with an original 1960/70's 'factory' RH tank.
Some hints and tips here:-
https://www.theminif...-kit/?p=1773953
and here:-
https://www.minimani..._right_gas_tank
Edited by mab01uk, 08 July 2023 - 03:31 PM.
Posted 08 July 2023 - 03:51 PM
Posted 08 July 2023 - 06:04 PM
Edited by imack, 08 July 2023 - 06:09 PM.
Posted 08 July 2023 - 10:35 PM
My RH tank hole is a mirror image of the LH tank. Never had any problem.
Posted 09 August 2023 - 03:45 PM
Just dug this out as I'm planning to do my own soon, hopefully help you guys out too! Popular Motoring Jan '71, Two Tank Mini!
Posted 09 August 2023 - 03:56 PM
when you have twin tanks do you have to push a button to switch from one to the other like an old landrover we used to have, or do they just join together into one fuel line feed
and, if the latter, presumably you only need a level sender in one of the tanks because they would go down at the same rate ? just something I've wondered in the past and never bothered to ask
Edited by stuart bowes, 09 August 2023 - 03:58 PM.
Posted 09 August 2023 - 05:03 PM
Been thinking about it for a while and "may" make a couple of cardboard template tanks then transfer the cardboard panels to sheet aluminium, form and tack together then get a competent Tig welder to do the business for me.
Can't seem to locate the right diameter filler necks yet though.
Posted 10 August 2023 - 09:56 AM
The latter...connected together with a solid line and yes just the one sender
Posted 10 August 2023 - 03:15 PM
Any chance of a decent scan of the article?
Posted 10 August 2023 - 03:31 PM
Find the centre of the filler hole on the template. Flip the template over and position on the right hand side and mark the centre of the filler hole in the body.
Cut out with a 70mm hole saw. Job done
I've just done this and it turned out spot on.
Posted 10 August 2023 - 05:41 PM
So this might be a stupid question for some reason but if the two tanks are joined with solid pipe and presumably there's a breather vent at the top of both how come you can't just fill up through one filler and it balances out into both sides equally. I.e the second tank shouldn't need a filler neck. Obviously there's a reason otherwise it wouldn't be made that way but I just don't see what that reason isThe latter...connected together with a solid line and yes just the one senderwhen you have twin tanks do you have to push a button to switch from one to the other like an old landrover we used to have, or do they just join together into one fuel line feed
Edited by stuart bowes, 10 August 2023 - 07:33 PM.
Posted 10 August 2023 - 05:48 PM
Posted 10 August 2023 - 07:12 PM
Posted 10 August 2023 - 09:48 PM
Ah ok so is it just that the pipe is too narrow for that to be effective
Yes, i had a kit car with twin tanks and one filler and the pipe between the two was about 5/8" and even then it took a while to fill it up.
