Ah ok so is it just that the pipe is too narrow for that to be effective
Yes it is a very small diameter pipe.
Posted 11 August 2023 - 05:26 AM
Posted 26 August 2023 - 04:19 PM
I did it years ago with much repeated measuring and a Starret holesaw.
Minispares used to sell a metal pipe that links the with a brazed on tee off for the feed to the fuel pump. I'm not sure if they still sell it.
[EDIT]
Minispares do still sell the connecting pipe. I had forgotten it was a Cooper S replica item - http://www.minispare...gs/21A2331.aspx
It was a long time ago but i think after fitting it, i thought it would be better to use a T piece on the LH tank to save a small loop of rubber hose coming into the boot.
There is less chance of puncturing a metal pipe in the boot than a rubber hose and the part is only £20, so no worries if you want to experiment
Edited by ac427, 26 August 2023 - 06:09 PM.
Posted 26 August 2023 - 09:31 PM
Posted 27 August 2023 - 03:49 PM
I was surprised to see the LH and RH tanks are almost the same price now. The RH tank always used to be about 5 times the price of the LH tank.
Is a stop valve really necessary, It might be worth trying it without at first and maybe adding one later?
Posted 27 August 2023 - 04:37 PM
Posted 27 August 2023 - 04:41 PM
Posted 28 August 2023 - 05:59 AM
Posted 28 August 2023 - 06:11 PM
The price difference back in the day was due to the low volume numbers during production of the RH tank compared to the LH tank, as it was only for the Cooper S models or the small aftermarket Special Tuning buyers.
Now the Mini is long out of production the low volume sales of both LH & RH tanks means once the tooling is made the price per tank is similar. In car manufacturing if you order 10,000 parts they will be a lot cheaper than if you order a 1000 of the same or similar parts....
Edited by mab01uk, 28 August 2023 - 06:13 PM.
Posted 29 August 2023 - 10:21 AM
I looking on ebay to see what they go for 2nd hand and I think I found the worst thing I've seen in a long time
https://www.ebay.co....:Bk9SR-zR7ozIYg
buy them all and destroy them lol
Posted 29 August 2023 - 10:40 AM
True but i thought because millions more LH tanks were made during production, that would help to reduce the expected return on a new LH tank.
Posted 29 August 2023 - 10:58 AM
This is the RH tank I've fitted into my 66 SDL. I used a motorbike fuel tap to isolate the tank before the copper fuel pipe. This is the Minispares kit.
I do have a cover for the battery.
Posted 05 March 2024 - 11:25 AM
Nice install. Did you need to remove and refit the RH boot board bracket to get the tank into place?
Also can anyone give me guidance on how the shorter of the two tank retaining straps is anchored to the boot floor, is it just through-drilled and bolted from below? Is there a specific location for it on the boot floor?
Posted 05 March 2024 - 03:17 PM
I fitted the boot board brackets after the tank. I drilled the boot floor for that bracket.
Posted 07 March 2024 - 09:53 PM
Posted 07 March 2024 - 10:21 PM
