Yes, I couldn't see how the thickness of the engine plate would have an effect here, unless the opening in it wasn't big enough for the front journal. It may put it in a slightly different location and that's all.
A lot of people knock some of these parts as not being fit for purpose etc when they don't fit out of the bag, however, some are supplied this way so the builder can adjust them (in this case by machining) to set them at the fit they are seeking.
Nah you were spot on, I was just grabbing at straws I think.
The fit was definitely fine tuned by machining, but I likely wouldn’t of had the confidence to go there without the forums guidance, so thank you!
