Removing One Of The Two Bk450 Head Gaskets From My Vmax Super Charger
Best Answer postve , 18 July 2023 - 03:26 AM
Yep and doing some calculations Tim and I find I am only getting 7.38 compression - using mini DIY compression calculator - does this make sense based on VMAX decompression plate
Chamber size - 25.5
Piston deck - 0.10
Bk450 -3.44
Crankshaft - 81.28
Piston size - 71.10 (.20 over bore) - 1293
Vmax decom/extra head gasket 12.4
I only get 8.21 compression and I have always wondered if I was down on this but will leave well enough alone . Just fishing for thought and thx
Note all calculations other than VMAX numbers were painstakingly done by me with help from Keith Calver Go to the full post
7 replies to this topic
#1 postve
postve
  • 473 posts
Posted 18 July 2023 - 02:16 AM
Hey folks
I was thinking tonight I want to experiment and remove one is the head gaskets from my cylinder head so I would end up with just decompression plate and one BK450. When I fit the SC I did the calculations and found I had 8.0down from original 9.5 - this was fine as per specs. Using classic mini DIY I got 7.86! What I am trying to figure out is how much increase in compression would result and whether or not my engine would go “nuclear” ? Curious if anyone has tried this before or has some input - thx for all who respond - expecting increase in performance if this works!
Edited by postve, 18 July 2023 - 02:46 AM.
#2 timmy850
timmy850
  • 2,997 posts
  • Local Club: MITG
Posted 18 July 2023 - 03:12 AM
You’ll need a head gasket on each side of the decompression plate otherwise it won’t seal
#3 postve
postve
  • 473 posts
Posted 18 July 2023 - 03:26 AM   Best Answer
Chamber size - 25.5
Piston deck - 0.10
Bk450 -3.44
Crankshaft - 81.28
Edited by postve, 18 July 2023 - 04:06 AM.
#4 timmy850
timmy850
  • 2,997 posts
  • Local Club: MITG
Posted 18 July 2023 - 05:56 AM
Yes adding a thick decomp plate and an extra gasket will give you a much lower compression ratio..
If you want to run higher compression with boost you need a very well tuned mapped ignition system and good quality high octane fuel
#5 postve
postve
  • 473 posts
Posted 18 July 2023 - 10:06 AM
Thx again Tim!
#6 IronmanG
IronmanG
  • 1,135 posts
  • Local Club: Box hill. Lsmoc member
Posted 18 July 2023 - 01:43 PM
Seeing as the ERA ran at 7psi at 9.7 (ish?) With injection that should be really easy to get to these days?
#7 timmy850
timmy850
  • 2,997 posts
  • Local Club: MITG
Posted 18 July 2023 - 09:38 PM
Low compression/boost/timing is the safe zone for a bolt on kit like the vmax.
The higher you push any three of those, the more time/money/engineering will go into making it work safely. It can definitely be done
#8 postve
postve
  • 473 posts
Posted 18 July 2023 - 09:51 PM
Sound advice and was just curious as to thoughts and agree more tinkering, more costs and substantial once ya start pushing the envelope
