Mini Sprite 1275 1992. Been off road for 4 months, replaced with new battery - will not start,no auxiliary either. 13 volts at battery , solenoid and steering column, all fuses checked, removed starter to test with battery,ok + solenoid ok . Help please
No Electric
Best Answer viz139 , 20 July 2023 - 08:29 PM
I would think you have a very poor connection on one of the main cables. main battery cable or boot earth. A poor connection will allow enough milliAmps through to power a multimeter or test lamp but no more .Nothing in the car is working, everything is feed through the earth strap in the boot and the battery cable to the starting motor so you need to check thoes four connections first.
Go to the full post
Posted 18 July 2023 - 06:48 PM
Posted 18 July 2023 - 07:08 PM
You say no auxiliary, what do you mean?
What size of battery did you purchase and how old is it? I get my mot station to order me the newest 063 size battery the supplier has... Don't use Euro car parts or Halfords.
You ideally want a Yuasa or Bosch brand battery
Edited by cal844, 18 July 2023 - 07:13 PM.
Posted 18 July 2023 - 07:41 PM
hi, no auxiliary - lights,heater horn etc nothing. new battery is 063 Lucas
Posted 18 July 2023 - 08:21 PM
Posted 19 July 2023 - 02:59 PM
Am i reading that right you have 13v 'at the steering column'
do you mean as in the main supply into the ignition switch
so if you're getting no aux power with the key turned, perhaps the problem is with the ignition barrel. should be a pretty simple task to bridge pins manually on the back side and see if power starts getting through that way
Im hesitant to point out which colour wires are which and make life really easy for any potential thieves but lets just say it's not overly difficult to work out
Edited by stuart bowes, 19 July 2023 - 03:01 PM.
Posted 19 July 2023 - 04:12 PM
No horn gives a bit of a clue, the horn circuit is fed directly from the battery via a fuse, but if as you say the fuses are ok, the problem might be that no power is coming to the master connection on the solonoid or the terminal connections are dirty.
You will need a test lamp as a minimum to fault find and I would start at the solonoid terminal and work out to the fuse box from there.
Posted 20 July 2023 - 08:29 PM Best Answer
Posted 26 July 2023 - 01:10 PM
Hi, Thank you to everyone for your input . I replaced both earth straps ,this solved the electrical problem,everything working ok
Posted 27 July 2023 - 10:17 AM
I guess I wasn't reading that right after all then lol
glad you got it sorted
