Mini 25 Speedo Pinion ?
Best Answer timmy850 , 19 July 2023 - 01:08 AM
The speedo drive gears need to match:
Tyre size
Final drive ratio
Speedometer turns per mile
You can work it all out here
http://www.guess-wor.../Tech/ratio.htm Go to the full post
1 reply to this topic
#1 mattyb
mattyb
  • 41 posts
Posted 18 July 2023 - 08:06 PM
Mini 25 with original engine and 12inch wheels - which speedo pinion should it have ? I've just pulled mine from the gearbox and its white with 17 teeth ?? so a 22a1881 ??
though the 22a1881 where for 10 inch wheels ??   any thoughts ? still trying to sort speedo !!
cheers
Matt
also I've just noted speedo adaptor is a 22A908 ??
Edited by mattyb, 18 July 2023 - 09:56 PM.
#2 timmy850
timmy850
  • 2,997 posts
  • Local Club: MITG
Posted 19 July 2023 - 01:08 AM   Best Answer
Tyre size
Final drive ratio
