Hi everyone, a couple of years ago I posted a query about overheating (the temp gauge had a habit of invariably creeping past 100C pretty much under any circumstances. I think after a couple of years of trying everything under the sun (engine filled with white vinegar for 7 days, new rad, new pump, various new gaskets, new gauge, new 82C thermostat) I've more or less finally solved it by simply fitting a wide fan spacer to bring the fan 8mm further into the cowl/duct on the rad. I still have some more testing to do but it definitely did far better on an hour's run yesterday than it's been for a long time, staying at 92C-95C and not rising above that. No problems with town driving, no problems with short waits at lights, no problems with 60mph on an A-road. (All temps are measured with an electric TIM gauge which seems to be quite accurate). Admittedly ambient temp outside was quite low at 17C.
I say I've more or less solved it, because on three occasions I 'simulated' a traffic jam by pulling over and letting it idle for several minutes. Each time, the gauge had risen to 100-102C within three or four minutes. So there's evidently still an issue with airflow when stationary.
Anyway, to get to the point, does anyone else think the aftermarket wheel arch liners might cause an issue with air flow for the rad? You can see from the pic that well over 50% of air discharged by my rad would end up over the TOP of the liner. I imagine this could be less of a problem on the move (air pressure in the wheel arches is presumably slightly negative (?) - the Bernoulli effect) but at a standstill it's difficult to believe that hot air finds an easy way out.
Any thoughts? Aftermarket liners are so popular I'd have thought someone else would have come across this problem if there actually is one, but I can't find any discussion of it on the forum.
