C7 Fuse Blown For Non Reason
electrical
2 replies to this topic
#1 Bijou1200
Bijou1200
    Starting My Mini Up
  • 1 posts
Posted 27 July 2023 - 01:26 PM
Hello Everybody , Gregory 47 from france and owner since few weeks of 1997 MPI cooper.
I'm struggling with a fuse C7 blown . When it's start it was 1 per week, now is all the time . Once I turn the key to ignition , the fuse blown out.
Could it be the MEMS relay Module ????
I disconnect fuel pump and replace the safety button and the fuse burn anyway.
I'm totally lost...
Thanks for your help . I love my english small car but it make me nervous to not finding the issue...
#2 Steve220
Steve220
  • 5,143 posts
  • Local Club: BMC
Posted 27 July 2023 - 05:51 PM
If you remove the plug from the inertia switch (safety button) does it still blow?
#3 mrriggs
mrriggs
  • 11 posts
Posted 29 July 2023 - 11:39 PM
If a fuse is blowing then it likely means you have a short circuit somewhere. The good news is that finding something that is shorted all the time is much easier than finding an erratic short.
Instead of "testing" it with a new fuse every time, you should use a test light in place of the fuse. Be sure the test light uses an incandescent bulb, not an LED. The idea is that the bulb will not only protect the circuit but also act as a visual indicator. If there is a short circuit then the bulb with light up brightly. Start flipping switch, unplugging connectors and/or jiggling wires until you see the test light flicker or go dim. Repair/replace whatever you found that is shorted THEN put in a new fuse.
