Hi guys, I'm in the process of fitting a new wiring loom to an 81 pickup, there was no loom fitted when I got the pickup, and I can't work out how the loom passes from the cabin area to the rear of the vehicle, there doesn't appear to be any points where it can exit the cab, any advice gratfully received.
Pickup Wiring Loom
Best Answer KTS , 30 July 2023 - 12:45 PM
there's a hole in the passenger side door post, high up under the waist rail, that the loom comes through
Go to the full post
Posted 30 July 2023 - 11:42 AM
Posted 30 July 2023 - 12:45 PM Best Answer
Edited by KTS, 30 July 2023 - 12:47 PM.
Posted 30 July 2023 - 12:48 PM
Edited by IronmanG, 30 July 2023 - 12:48 PM.
Posted 30 July 2023 - 03:11 PM
That's great, thanks for that, I'll go and have a look and see if I can locate the hole.
Posted 30 July 2023 - 03:26 PM
...don't be tempted to use the gap between the b-post and side panel you can see in the photo above; it's got sharp edges and will shred the loom wrapping as you pull it through
...and don't do what i did in the first photo
