Spi Fuel Priming Process
Best Answer NotMyMini , 01 May 2024 - 02:21 PM
Just in case anyone has a similar issue, I've since discovered that the +12v feed for the Fuel Pump had been spliced in to a switched live.
Go to the full post
4 replies to this topic
#1 NotMyMini
NotMyMini
  • 13 posts
Posted 04 August 2023 - 02:19 PM
Hi everyone :)
Please would someone be able to describe the process the fuel system should go though on normal day before and after starting?
We are currently seeing the following:
  • Key is turned to position 1: Nothing (as expected).
  • Key is turned to position 2: Fuel pump springs to life and runs constantly.
  • Key is turned to crank: I believe the pump is still runs. Engine cranks but does not start (that's a story for another time).
  • Key is returned to position 2: Fuel pump continues to run.
Once the key was at position 2, I would have expected to the fuel pump to cut out after a short amount of time but it seems to run constantly.
Please would someone be able to confirm.
#2 MatthewsDad
MatthewsDad
  • 899 posts
Posted 04 August 2023 - 04:25 PM
Fuel pump should stop after a few moments at position 2
#3 NotMyMini
NotMyMini
  • 13 posts
Posted 04 August 2023 - 05:43 PM
Thank you :)
I wonder why it keeps running in our car.
Would you happen to know what triggers the pump to switch off after it's primed? Is it purely a time based operation, or is there something monitoring the fuel pressure?
Edited by NotMyMini, 04 August 2023 - 05:47 PM.
#4 genpop
genpop
  • 536 posts
Posted 05 August 2023 - 06:06 AM
Read this thread:https://www.theminif...-functionality/
Possibly the points for the fuelpump are melted together.
Edited by genpop, 05 August 2023 - 06:15 AM.
#5 NotMyMini
NotMyMini
  • 13 posts
Posted 01 May 2024 - 02:21 PM   Best Answer
Edited by NotMyMini, 01 May 2024 - 02:21 PM.
