Excessive Ride Height On Dry Suspension Saloon
1 reply to this topic
#1 ac427
ac427
  • 679 posts
Posted 11 August 2023 - 04:46 PM
I went to look at a 10" wheeled Mini saloon with dry suspension, a few days ago.
The height from the top of the tyres to the wing lip was around 6 inches on all 4 corners.
The does not have HiLo's.
It may have been stored on axle stands in the past. Could this be the cause?
#2 mab01uk
mab01uk
  • 12,514 posts
Posted 11 August 2023 - 07:30 PM
I assume extra washers have not been added between the trumpets and the knuckle joints which was a method of raising ride height before Hi-Lo's appeared in the 1970's?
These are the factory washers to raise the suspension.
3.41mm thick. Suspension has a 3:1 ratio on front and 5:1 rear:-
https://www.minispar...ic/21A1845.aspx
Edited by mab01uk, 11 August 2023 - 07:34 PM.
