Any recommendation for a convex Overtaking type mirror which fits on a mk1 without drilling holes. All the ones I've seen have a flat mirror glass which is totally useless.
Best Answer whistler , 24 August 2023 - 09:05 AM
I've ordered a set of those mirrors.
Go to the full postPosted 23 August 2023 - 10:07 AM
Posted 23 August 2023 - 02:36 PM
no; they're pretty solid.
the only issues i found were that the window catches needed a little bit of modifying for the bolts to go through and the nuts to tighten, and the mirror position has to be a compromise between window open and window closed.
the biggest issue I can see with this setup is the potential for the window to shatter if the door mirror is clipped hard enough....
Posted 24 August 2023 - 09:05 AM Best Answer
