Check Arm Grommet Fitting - 1970-1986
Best Answer sonscar , 30 August 2023 - 05:23 PM
I remember they had a plastic push in plug?Steve.. Go to the full post
6 replies to this topic
#1 chuee
chuee
  • 117 posts
Posted 30 August 2023 - 12:26 PM
I wonder, when fitting  check arm grommets, I.E. the rubber moulded type found here https://www.minispar...MS.aspx|Back to,  are they supposed to be fixed with a  self tap screw ? I notice a small  hole in the A panel to which it fits. Having merely plamcing it in position  I find it wanders about.
Mine were missing when I took over the car several years back. Cant remember if I removed a screw remaining there,  when preparing for painting.
Cheers John
Edited by chuee, 03 September 2023 - 12:24 AM.
#2 whistler
whistler
  • 1,706 posts
Posted 30 August 2023 - 01:59 PM
I bought new ones a few years ago but they were rock hard and the door wouldn't shut so opted for the later close cell foam ones. Much better. You could make your own if you have some closed cell foam soundproofing sheets about.
#3 sonscar
sonscar
  • 2,726 posts
Posted 30 August 2023 - 05:23 PM   Best Answer
#4 bpirie1000
bpirie1000
  • 2,119 posts
  • Local Club: Amoc
Posted 30 August 2023 - 05:38 PM
Remember a wee plastic plug also
#5 pogie
pogie
  • 498 posts
  • Local Club: Essex MC
Posted 31 August 2023 - 02:32 PM
IIRC mine came with double sided tape on the back, no screws needed.
#6 Rorf
Rorf
  • 859 posts
Posted 01 September 2023 - 06:30 PM
Stick it onto the A pillar with contact adhesive
#7 chuee
chuee
  • 117 posts
Posted 03 September 2023 - 12:23 AM
Thanks to all for your replies. I do have the rubber ones, not the foam. The door shuts nicely with them on. I've used a self-tapper with large head, not knowing about the wee plug, but I'll get some.
Edited by chuee, 03 September 2023 - 12:23 AM.
