Any Clever Ideas For Replacing These?
7 replies to this topic
#1 MikeMPi1999
MikeMPi1999
  • 47 posts
Posted 01 September 2023 - 10:59 AM
Im going to need 4 sets of wheel arch studs for my mini and £120 for 20 studs is a bit steep for my restoration project. See attached.
Intrested in alternative ideas, work arounds or possible off the shelf items that are similar?
Any ideas?
Thanks.
#2 whistler
whistler
  • 1,706 posts
Posted 01 September 2023 - 11:48 AM
Button head allen bolts in stainless. Either use Stainless nuts or rivnuts.
#3 stuart bowes
stuart bowes
  • 1,591 posts
Posted 01 September 2023 - 12:11 PM
if any are out of reach behind the petrol tank, I'd stick a bit of locktite on if you rivnut them, to make sure it doesn't just spin
all the others would be easy enough to get at the back side
Edited by stuart bowes, 01 September 2023 - 12:12 PM.
#4 MiniJosh92
MiniJosh92
  • 1,691 posts
Posted 01 September 2023 - 12:23 PM
Smiffys bits do them a bit cheaper and in stainless - https://www.ebay.co....7AAAOSwT9NdreOp
#5 MikeMPi1999
MikeMPi1999
  • 47 posts
Posted 03 September 2023 - 09:13 AM
Would somthing like this work?
https://shop4fastene...less-steel.html
or this if i can find them in stainless:
https://www.accu.co....RhoCjM4QAvD_BwE
#6 stuart bowes
stuart bowes
  • 1,591 posts
Posted 03 September 2023 - 10:52 AM
I wouldn't rely on either of those personally the problem is you're going into thin sheet steel so there won't be enough thickness for a thread to be of any real reliable use
Hence the originals go through a hole and are bolted on the other side, or the rivnuts which obviously get held in by the flange on the back side once squeezed in place
#7 ClassicBRG
ClassicBRG
  • 75 posts
Posted 05 September 2023 - 01:52 PM
I glued some M8 threads (bolts with cutoff head) into the sportspack arches with 2K epoxy.
Very cheap and reliable in my opinion..
#8 MikeMPi1999
MikeMPi1999
  • 47 posts
Posted 06 September 2023 - 10:43 AM
Great! im looking for some stainless and will do the same. Thanks for confirming this.
