HI all,
So I have been reliably informed that you can increase the Inlet body to 44mm and a HIF44 carb butterfly valve will fit perfectly.
Questions -
1 - Does any body know the tolerances for the bore hole?
2 - What surface finish do I need - Does it need to be honed or just bored?
I have also seen a 45mm inlet body kit with a adjustable fuel pressure regulator avaliable from japan -
Further questions -
1 - does it make any sense to do either of these modifications with a standard head with normal stage one upgrades or should these modifications be done with a stage 3 head???
2 - If done with a stage 3 head will all these modifications be too much for the standard ECU?
I Have a SPI cooper compression spec mini.
Thanks Jason
Edited by R32Egor, 26 September 2023 - 07:08 AM.
