52Mm Rev Counter Suggestions
19 replies to this topic
#1 BaronVonchesto
BaronVonchesto
  • 515 posts
Posted 11 October 2023 - 04:29 AM
Would like to fit a rev counter for my car. I have the classic tripple clock setup.
Most people go for the 80mm smiths one, but I'm thinking a 52mm one would look better. I'm aware that minispares sell one by smiths but I just don't like the look of it?
Have tried scouring fleabay for a few others, there are some cheapo ones going for $20-$30 that might do the trick, but I get the feeling they will always look out of place, especially as they tend to come with LED lights instead of incandescent.
Anyone have other suggestions I might consider? Something that would fit in with the classic dash.
Edited by BaronVonchesto, 11 October 2023 - 04:29 AM.
#2 mini-mad-mark
mini-mad-mark
  • 852 posts
  • Local Club: northants wot no brakes
Posted 11 October 2023 - 08:30 PM
Try searching for 2 inch (the old name for 52mm) also I guess why gauges ended up at 52mm and not 50mm?
Like this:
https://www.ebay.co....6wAAOSwi4Vjc8gH
#3 Steam
Steam
  • 761 posts
  • Local Club: Victorian Mini Club
Posted 12 October 2023 - 01:51 AM
As with everythung else if you google it there will be hundreds of pics to choose from.
#4 Midas Mk1
Midas Mk1
  • 5,778 posts
  • Local Club: S.U.N.M.C
Posted 12 October 2023 - 05:08 AM
Sign of the times im afraid, whats google? research?  O_O
#5 sonscar
sonscar
  • 2,999 posts
Posted 12 October 2023 - 07:26 AM
I am a luddite yet Google is my first port of call.Is this because I am being left behind?Steve..
#6 Bobbins
Bobbins
  • 1,488 posts
Posted 12 October 2023 - 07:51 AM
Agreed.
For anyone not familiar with getting the best out of Google (and to aid the OP), open the Google search page, type in "52mm rev counter" (and hit return), then select the "images" tab at the top. There's 100s to choose from, just select the style and source location that suits you.
#7 maccers
maccers
  • 1,868 posts
  • Local Club: LSMOC
Posted 12 October 2023 - 03:38 PM
I have an 80mm one from Smiths and run the centre 3 clock dash. I put the rev counter on the driver side air vent, fits perfect!
#8 I hate Brian
I hate Brian
  • 782 posts
Posted 12 October 2023 - 06:19 PM
I've got this fitted looks mint  https://nippycarsonl...-binnacle-dk2r/
#9 stuart bowes
stuart bowes
  • 2,115 posts
Posted 12 October 2023 - 07:59 PM
in fairness to OP it's not actually as straight forward as 'just go and look on google' and I think we can do a little better than just sending people off to work it out for themselves can't we, isn't that the whole point of a forum
he's quite right, they are mostly larger types or questionably cheap with high likelihood of tacky crap LED backlighting which would stick out like a sore thumb, or worse a hideous LCD readout, it's not knightrider jeez
personally I would say why not convert to the later style with the rev counter, and the clocks right in front of you which actually I prefer anyway (though I appreciate that is just personal taste and not 'better or worse') like this but find one at a sensible price obviously https://www.ebay.co....:Bk9SR-LP7tfkYg
alternatively depending on your budget have you tried the usual motorsports suppliers, for example Merlin have these https://www.merlinmo...00rpm-333015010 but you'd have to phone or email and ask what type of back lighting they have because it isn't obvious on the webpage (or I didn't see it anyway)
Edited by stuart bowes, 12 October 2023 - 08:10 PM.
#10 BaronVonchesto
BaronVonchesto
  • 515 posts
Posted 26 November 2023 - 04:27 PM
its been a while since I responded to this thread but thank you all for the suggestions. I did in fact try the googling method, but there's so much ugly generic stuff out there that I decided it would be better to ask for specific suggestions from people rather than searching blindly through thousands of options.
I quite like the Yazaki ones. and there is also a VDO one which I think would look perfect but is really expensive, so Yazaki it is.
Does anyone know if this model is 2"? The listing doesn't say but looking around yazaki tachs, this does fit the bill. I have messaged the seller asking him to measure it just in case.
https://www.ebay.co....tm/285554910553
Would this yazaki work with a electronic ignition dizzy? Im suing Minispares C-27H7701
#11 BaronVonchesto
BaronVonchesto
  • 515 posts
Posted 26 November 2023 - 04:34 PM
Alternatively, this one from TIM isn't too bad either. Though again, I'm not sure if it will work with my dizzy.
https://www.ebay.co....tm/305283086353
#12 BaronVonchesto
BaronVonchesto
  • 515 posts
Posted 27 November 2023 - 02:34 PM
anyway if anyone else is interested those Yazaki's are in fact 52mm though it appears to be a RVI type rev counter so it may not work with my electronic dizzy without some additional electronics. Worth a shot though.
#13 timmy850
timmy850
  • 3,335 posts
  • Local Club: MITG
Posted 27 November 2023 - 07:38 PM
That Yazaki appears to be a similar age to the one I’ve just installed (same colour wiring). Mine works fine with electronic ignition
Here’s a brochure
https://mk1-performa.../pdf/yazaki.pdf
#14 68+86auto
68+86auto
  • 911 posts
  • Local Club: Queensland Mini Car Club
Posted 29 November 2023 - 10:42 PM
I was about to suggest looking at VDO options but it looks like you already found them.
#15 croc7
croc7
  • 810 posts
Posted 30 November 2023 - 08:27 AM
Mooneyes 2 5/8” tach. A bit expensive but a nice throwback to the early 60s days of hot rods.
