Anybody??
4 Pot Metro Brakes Questions
#16
Posted 19 October 2023 - 01:47 PM
#17
Posted 19 October 2023 - 01:55 PM
No need for fancy (expensive) drilled or grooved disc.
Greenstuff pads are generally considered a poor performance pad (although some like them). I would suggest Mintex 1144 for fast road.
#18
Posted 19 October 2023 - 01:57 PM
It looks like .. the advice here is saying remove the spacers and use normal non-vented discs and then there is no problems
that's not really how I read it, I think the advice was more along the lines of leave them and go for standard mini calipers, but opinion was a little divided about whether or not the difference in hub geometry causes issues with handling
in terms of discs it seems vented / drilled etc is not required
Edited by stuart bowes, 19 October 2023 - 01:58 PM.
#19
Posted 23 October 2023 - 08:09 AM
If i remove the spacer plate in the calipers and make them usable for non-vented discs, I will need a new fitting kit.
The fitting kit for this available in minispares - GBK1017 - does not appear to be available anymore.
Were these calipers *standard* on all metros? Which years were the non-vented version used on metros?
I ask because i found a fitting kit on ebay with the following Austin part number - 1011036 - would these be the ones?
#20
Posted 23 October 2023 - 01:08 PM
Only the early vented calipers, off the Turbo Metty, had spacers. When they all went over vented discs the calipers were made without needing a spacer.
Any difference in offset will only be seen via whatever wheels you have, but you'll still have the discrepancy with the rear end.
I inherited a set of Metro swivel hubs from a previous owner, it handled pretty well on them. Alas, I didn't investigate the set up in any detail.
#21
Posted 23 October 2023 - 06:57 PM
Last question - normal discs or grooved and crossdrilled? and are the green stuff pads ok or too much?? (stage 1 right now and looking for stage 3 and 90 HP later).
I've always noticed that drilled discs develop surface cracks from the drilled holes. I find that worrying, though, I also have to say, I've net seem them fail or break as a result of the holes. Also, the way I look at it all is that you want to increase surface area here between the pads and disc, not reduce it, which is what holes and slots do.
My Metro, a 1980 model, has solid discs on it, same as those from a Mini. It wasn't until the Metro Turbo was introduced that Metro got vented discs.
The Calipers will fit up on a Mini Hub with a Standard 8.4" Mini Disc and a Standard 8.4" Disc Drive Flange, once the spacer in the Caliper is removed. There's also slightly longer Caliper Mounting Bolts available.
#22
Posted 24 October 2023 - 06:48 AM
Thanks all should be able to find the correct fixing kit from that information.
#23
Posted 24 October 2023 - 10:43 AM
I think it was '85 when all Metros got vented discs.
Not sure if we mentioned the mounting holes are slightly different, Metty's using Metric bolts. Minispares do a bolt for fitting 'em to Mini hubs ERA1128
and while we're at it, the bleed screws are very delicate, replacing them would be a good idea
#24
Posted 24 October 2023 - 01:49 PM
As I have said mine were flawless as regards handling with 3/8" extended bottom arms and mini steering arms but other people's experiences have been terrible.
I wonder if the terrible experiences were just with vented setups?
Who knows!
#25
Posted 24 October 2023 - 02:49 PM
I'm not sure there was. You might still be able to see any change points & parts numbers on Rimmers site, or similar.
The arms certainly looked like they'd give more roll induced camber than a Mini & the, original steel, wheels had a stupid amount of inset in comparison.
#26
Posted 24 October 2023 - 04:37 PM
Reading through all this and people's experience with metro hubs and brakes makes me think that there was probably a set of hubs that were different to the "normal" sets that were available. Maybe a run where the kingpin angle was different?
Who knows!
As per Calvers article there were some differences. But they all had the same part number. None were much good.
#27
Posted 04 November 2023 - 08:43 AM
Coming back to this post.
I have realised that once i remove the spacers between the 2 sides of the caliper - i will need new shorter bolts.
I have searched Mini Spares for any hint of what bolts i will need but cannot find anything, all i found is the bolts that are needed to attach the calipers to the hub.
Has anybody got any ideas of a part number or where I could get a set of bolts?? Or what thread they are?
Just a thought - Can I use the original mini caliper bolts?
Edited by R32Egor, 04 November 2023 - 08:47 AM.
#28
Posted 04 November 2023 - 09:16 AM
They are an odd ball bolt from memory ! M8 shank with a 5/16" UNF Thread. You could use 5/16" UNF Bolts, but watch the alignment of the 2 halves or they can leak at the bridge seal. I made mine from M8 Inhex Bolts.
#29
Posted 06 November 2023 - 05:34 PM
#30
Posted 07 November 2023 - 02:25 AM
I couldn't determine what the originals were so that was in part why I opted for Inhex Bolts - in Unbrako, they are Grade 10 at that size.
