ENGINE AND FUEL TREATMENT
19 replies to this topic
#1 Mark1275GT
Mark1275GT
  • 487 posts
Posted 17 November 2006 - 02:11 AM
Bonjour lads. :w00t:
Could someone tell me whats the best ENGINE AND FUEL TREATMENT ?
Thanks ;)
#2 miniboo
miniboo
    Lord of Original Thinking
  • 9,327 posts
Posted 17 November 2006 - 08:49 AM
i put redex in the petrol
#3 Big_Adam
Big_Adam
  • 7,435 posts
Posted 17 November 2006 - 09:35 AM
engine,
Well a nice 5 star restaurant sees to work well.
#4 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 17 November 2006 - 10:09 AM
If you're talking about leaded fuel additives then I use Castrol Valvemaster Plus
If you're talking about anything else, then don't....
#5 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 17 November 2006 - 10:25 AM
Aye castrol valve master gets my vote too, I used to use, but gave my box of 47 syringes to Zenob1, what a ncie guy i am lol!
Treatment for what?
#6 BabyBek
BabyBek
    I love sheepies
  • 1,212 posts
  • Local Club: TMF and South Wales Minis
Posted 17 November 2006 - 10:29 AM
I have used wynns engine treatment in the past.... I'm not convinced!
#7 Mark1275GT
Mark1275GT
  • 487 posts
Posted 17 November 2006 - 11:29 AM
redex :w00t:
Thats good then.
What about engine ? its unleaded ;)
#8 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 17 November 2006 - 11:33 AM
woah hang on,. why do you need treatment?
Castrol Valve master is a lead replacement fluid used on leaded engines. You only use other treatments if there is a need for it..... which would usually indicate some other, more serious, problem.
The same applies to ALL other treatments, only use if NEEDED. I would recommend running on BP ultimate or Shell V-Power (re-branded optimax) if your just trying to get it running nicer.
treatments aren't cures,... they just hide symptoms.
As Guessworks said...
Edited by Retro_10s, 17 November 2006 - 11:37 AM.
#9 Mark1275GT
Mark1275GT
  • 487 posts
Posted 17 November 2006 - 11:58 AM
[quote name='Retro_10s' date='Nov 17 2006, 10:33 AM' post='384938']
When i start the car, a little bit of black smoke comes out. once its warm it goes.
so was told it might need some treatment.
So this optimax unleaded petrol. whats the idea. just cleans your fuel system?
would it clean the carb as well ?
#10 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 17 November 2006 - 12:03 PM
ahhh i see, yeha you don't need treatment for that.
Optimax/V-power and BP ultimate have all sorts of detergents chemicals in that clean the fuel syste through safely, also isn't the RON higher than normal unleaded?
just chuck a couple of tanks of the above fuels through first and go for a blast down the motorway. if you'r getting black smoke it's likely that you're running slightly rich which is why you're getting more black build up.
please, try the fuel first, and maybe have a looky at your mixture too.
#11 Mark1275GT
Mark1275GT
  • 487 posts
Posted 17 November 2006 - 12:26 PM
Ok ill try that Optimax for unleaded.
I just looked at me plugs. and there bit black :'(
But thats how the guy tuned it. not on rolling road tho.
Would it run worse on my mg metro turbo if i mess around with the mixture ?
Never messes around with the mixture before.
It is that easy doing it on a HIF44 CARB ? thanks mate
#12 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 17 November 2006 - 01:05 PM
you're running ruch then., i would run the fuel through, this will at least clean it up in there, but your mixture needs leaning off. (so that there's more air in twith the fuel mixture.)
healthy plugs have a kinda very light brown film on them i think.
Edited by Retro_10s, 17 November 2006 - 01:06 PM.
#13 Jammy
Jammy
  • 25,397 posts
Posted 17 November 2006 - 01:08 PM
You don't need to run any treatment or anything, you just need to have your car set up properly on a rolling road.
#14 Garagiste
Garagiste
  • 336 posts
Posted 17 November 2006 - 02:19 PM
MG metro turbo would be pre-unleaded though surely? :w00t:
So unless you've had an unleaded head swap then a lead replacement additive would be a good idea.
I've been using Valvemaster plus after reading good reviews here, but I'm interested that neither of the magazines ever gives it a mention - they always reccommend Millers SIP or Red line.
Anybody have experience with those? (And apologies for the thread hijack, but a search turned up nothing so using the active thread seemed to make sense).
#15 Jimmyarm
Jimmyarm
    Entrepreneur of Adult Material
  • 2,239 posts
  • Local Club: TMf
Posted 17 November 2006 - 02:29 PM
Just out of curiosity, if you stick it in third at about 15mph and then floor it, do you get lots of smoke coming out the back ?
