Eyeball Vent Rebuild - Suggestions For Foam Tape
Best Answer MiniTim71 , 20 October 2023 - 06:16 PM
Guys, many thanks, some really good inspiration here which got me thinking.
I bought some adhesive backed felt £1 from Hobbycraft and cut it into 10mm strips with a metal rule and stanley knife.
Then carefully fitted it into the groves the original felt came out of.  The Hobbycraft felt was a little thin and I needed to put 2 layers on.
Next I popped the eyeballs back in and the fit was perfect, just the right amount of friction but easy to move and adjust.
Thanks again.
Go to the full post
10 replies to this topic
#1 MiniTim71
MiniTim71
  • 36 posts
Posted 19 October 2023 - 07:54 PM
Hi,  I am cleaning/rebuilding a pair of eyeball vents for my '71 as I am going back to original dash having removed previous owners wooden dash.
Does anyone have experience or suggestion for the foam sticky tape which sits between the eyeball "socket" and the eyeball itself?
The foam provides the friction as you turn the eyeball and also stops air whistling past.
Any help appreciated.
Tim
Attached File  20231019_204928.jpg   56.59K   2 downloads
#2 stuart bowes
stuart bowes
  • 2,111 posts
Posted 19 October 2023 - 09:13 PM
Unless someone comes up with a better idea my first thought would be cut a strip of felt around the right thickness and neatly glue it in around the inside
something along these lines maybe https://woollieandfe...felt-dark-black
using a glue which isn't too wet and doesn't soak into the fabric making it go all hard, you want it to stay 'cushiony' for want of a better word.  pritt stick is surprisingly good for these kind of situations silly though it might sound
Edited by stuart bowes, 19 October 2023 - 09:16 PM.
#3 Ethel
  • 25,923 posts
Posted 19 October 2023 - 09:42 PM
If you have on old fleece jacket or similar knocking about it might be worth a go. Double sided sticky tape might be the way, if you can get it back together it shouldn't have much to do & stay stuck.
#4 MatthewsDad
MatthewsDad
  • 812 posts
Posted 19 October 2023 - 09:52 PM
I've used felt cut to size in the past
#5 71Pickup
71Pickup
  • 94 posts
Posted 20 October 2023 - 02:36 PM
There is loads available online just google sticky black felt tape should be about £6 per roll
#6 MiniTim71
MiniTim71
  • 36 posts
Posted 20 October 2023 - 06:16 PM   Best Answer
Thanks again.
#7 MiniTim71
MiniTim71
  • 36 posts
Posted 02 December 2023 - 12:44 PM
Attached File  20231030_103017.jpg   60.1K   7 downloads
Hi, just thought you might like to see the end result.
Restored Binnacle and Eyeball Vents.  Dash trim kit from Optimise Automotive.
Upper dash rail and A pillars trimmed with Leatherette
Chrome upper dash vents and ashtray form Mini-Spares
Tim
#8 71Pickup
71Pickup
  • 94 posts
Posted 02 December 2023 - 04:33 PM
Looks good - a nice place to be
#9 unburntfuelinthemorning
  • 1,983 posts
Posted 06 February 2024 - 04:36 PM
Tim
That looks great.  I love the look of the original dash.  Nice touch with the covered top dash rail too.  You say in your original post the car's a '71.  Is that a typo or have you fitted later switchgear?
#10 MiniTim71
MiniTim71
  • 36 posts
Posted 07 February 2024 - 09:59 AM
Tim
Hi, the car is a 1971 Morris Mini 1000.
However in 1999 a lady commissioned a Mini Builder to build her a Mini.  They used the '71, a Metro 1275 engine and a new Heritage shell.  They weren't too fussy about originality.
I bought it 3 years ago, shell was near perfect but car was in a tired state.  I set about restoring it to as period look as possible.
I would focus on returning to Mk3 but give a little leeway for 60's/70's parts.
Horrid wheel arches came off and chrome trim replaced after paint work.
Full suspension rebuild, all adjustable.  10" Wheels and Cooper S disks.
The dash project shown here ...
Return to Mk2 rear lights
Replace the MINI1000 badge on the boot
100's of hours on detail
Gloss black roof (mk3 option)
And that 1275 is now at Oselli having a full rebuild to 1310 Stage 2 with a torquey road cam.
Your right about the switchgear.  Now you have pointed it out, another job on the list :)
Tim
ps  we both seem to be in Bedfordshire ...
#11 unburntfuelinthemorning
  • 1,983 posts
Posted 10 July 2024 - 11:14 AM
Tim
Tim
Sorry about the late response, I'm so behind with keeping up with the forum.  Do you have the engine back from Oselli yet?  What part of Bedfordshire are you in?  I'm in the south closer to Hitchin.  I'm moving to Cambridgeshire next month though.
