Mini Sky Replacement A Panel
16 replies to this topic
#1 Edington
Edington
  • 127 posts
Posted 31 October 2023 - 09:50 AM
I am replacing the right hand (O/S) A panel on my son's 1988 Mini Sky and am a bit puzzled by the fitment. Bought a new panel from Mini Spares but the vertical edge that runs along the door hinge plate is no where close to were it should be (see photos). I noticed the rusty one I removed had a narrow edge folded over and fixed to the hinge plate. On this new one there is far to much metal sticking out passed the hinge plate. All the other edges fit well. Any thoughts?
#2 sonscar
sonscar
  • 3,000 posts
Posted 31 October 2023 - 09:58 AM
You have a bit missing over which the angle folds.This bit is part of the A pillar.Steve..
#3 Edington
Edington
  • 127 posts
Posted 31 October 2023 - 06:11 PM
Ok thanks. It might have disappeared in a pile of rust! I think I'm going to temporally refit the door and see if it doesn't fowl the door. If it's ok I'll see what the bit is that's needed.
#4 stuart bowes
stuart bowes
  • 2,121 posts
Posted 31 October 2023 - 08:42 PM
that's the bit we've been talking to Victor about recently see post #813 onwards https://www.theminif...stripey/page-55
#5 Edington
Edington
  • 127 posts
Posted 01 November 2023 - 07:44 PM
Thanks for this information. It looks like I need a R/H  A Post inner hinge panel MK3 on which is M-Machine part 13.14.03.04.
Interesting that the original production build has the edge nearest the door folded over!
#6 sonscar
sonscar
  • 3,000 posts
Posted 01 November 2023 - 07:48 PM
The edge near the door does fold over the missing part,similar to the doorskin fold,Steve..
#7 mab01uk
mab01uk
  • 12,426 posts
Posted 01 November 2023 - 08:08 PM
The folded over part of the Mk3 on-wards A-panels is often where the rust starts, usually first noticed when the factory spot welds start to dimple and bulge as the rust expands inside the seam. Once the A-panel is replaced apply plenty of Waxoyl into the folded over seam to prevent it happening again...
#8 pete l
pete l
  • 1,370 posts
Posted 02 November 2023 - 07:32 AM
Why is everyone saying there is a missing part ? I can't see a missing part.
Can we have a picture without the A panel in place ?
#9 stuart bowes
stuart bowes
  • 2,121 posts
Posted 02 November 2023 - 09:12 AM
looking down the A pillar where you can see the bolt holes..
there's supposed to be a folded edge pointing towards the rear of the car that you fold the edge of the A panel over (a fold at the edge of the flitch panel)
without that there's nothing to hold the A panel on the car except a small weld at the top, and a small weld at the bottom (and obviously the front wing)
Edited by stuart bowes, 02 November 2023 - 01:01 PM.
#10 Edington
Edington
  • 127 posts
Posted 02 November 2023 - 10:06 AM
Hi Guys, Been looking at all the links and photos and can see what is missing (see my original photos). I'm struggling to determine the M-Machine panel part number. Thought it was 13.14.03..04 but it doesn't look right?
#11 stuart bowes
stuart bowes
  • 2,121 posts
Posted 02 November 2023 - 10:41 AM
I would have thought it's the edge off of this bit you need https://www.minispar...px|Back to shop
or M-machine's equivalent if you prefer
it's a shame really because you're just going to be cutting the edge and welding it on not using the whole piece
I got a flitch panel just for one small piece and ended up using the rest of the panel cut up into pieces for various patches and fabriation of small parts
#12 stuart bowes
stuart bowes
  • 2,121 posts
Posted 02 November 2023 - 01:06 PM
I just remembered someone asked about this in the past and I did some measurements
you could just weld a strip of .9mm down the edge and trim it to the right curve..
https://www.theminif...a-panel-flange/
although if you have the A panel already you could just trace the curve which would be easier
Edited by stuart bowes, 02 November 2023 - 01:08 PM.
#13 colinf1
colinf1
  • 1,015 posts
Posted 02 November 2023 - 04:22 PM
Here's another measurement I did previously for Victor...
At 100mm spacing to give a rough curve
#14 stuart bowes
stuart bowes
  • 2,121 posts
Posted 02 November 2023 - 04:44 PM
yours might be more useful then.. assuming you measured to the edge of the A post which seems logical
mine was an arbitrary line which gives a nice accurate curve but was intended for someone who had the top half already in place and wasn't trying to create the whole thing from scratch
Edited by stuart bowes, 02 November 2023 - 07:29 PM.
#15 colinf1
colinf1
  • 1,015 posts
Posted 02 November 2023 - 11:26 PM
Both of our measurements seem to match up until the bottom bit, mine was measured from a new heritage inner wing, but I believe some people trim these back when fitting the A panel to allow more adjustment for door shut lines/clearance.
