1987 Mini City
91 replies to this topic
#76 Hexxeh
Hexxeh
  • 106 posts
Posted 11 August 2025 - 08:42 PM
Is it using all braided hoses rather than hard lines with braided to calipers that's causing the issue? It's maybe finding a weak spot on the diagonal hose that's reducing pressure to that caliper?
Possibly? Though if anything I'd expect that to make the passenger side weaker, not stronger?
Have you bedded in the new pads and discs properly?
New calipers can also have slightly sticky pistons that haven’t found their ideal resting position yet and perhaps one is taking more travel to contact the disc. You should be able to inspect the pads & see if they have much wiggle room at rest, and then observe how they contact the disc when someone presses the pedal down
I haven't done anything particularly special, just did a few firm but not super hard stops to check all seemed ok.
I popped both front wheels off again today before I headed out to my first meet. Checked each piston individually on both calipers, all four each side move ok. Swapped the pads side to side, made no difference. Only thing I did notice is that if I spin the hub on the bad side, it's perfectly smooth. If I spin the hub on the bad side, the pads "knock" back and forth slightly as it contacts them. My first thought is that perhaps somehow the disc is very slightly not true and so that side grabs more, but I'm not really sure how to check. I guess mount a DTI up somewhere on the suspension and then see how the reading changes as I spin the wheel? I guess I could swap the discs side to side, gotta find that seating washer for that though...
Edited by Hexxeh, 11 August 2025 - 08:48 PM.
#77 Hexxeh
Hexxeh
  • 106 posts
Posted 14 August 2025 - 10:00 AM
Mini Sport came back to me, basically suggested swapping the calipers side to side (bleeding off the disc to account for the fact the bleed nipple would be at the wrong side), and then if the bad side doesn't move, try swapping the discs. I'd already tried swapping the pads. If neither of those moves the bad side, it must be the flexi or t-piece/banjo. Bit of a faff but I suppose it will narrow down what the issue is without buying any new bits.
#78 Hexxeh
Hexxeh
  • 106 posts
Posted 14 August 2025 - 06:25 PM
Swapped the calipers (holding off the disc the bleed nipple up to bleed), no change, still pulls left when braking. I can't find the flat washer to seat the bearings again if I swap the discs, but I really can't see it being the disc itself... I think it has to be the hose or banjo bolt at this point?
The fact the hose around the subframe is a braided flexi couldn't cause the driver side to be weaker, could it?
Edited by Hexxeh, 14 August 2025 - 06:59 PM.
#79 stuart bowes
stuart bowes
  • 2,617 posts
Posted 14 August 2025 - 07:30 PM
I would say that's possible yeah, previously you had the solid lines which meant the flexis were the same length at each end.  but now you've got one about 8" long and one about 40" long
I don't know a lot about fluid dynamics or anything but gut feeling it's possible the longer side would 'absorb' more of the fluid and leave the shorter one lacking, something to do with the path of least resistance or something .. maybe
have you still got the old pipework to hand?
Edited by stuart bowes, 14 August 2025 - 07:31 PM.
#80 Hexxeh
Hexxeh
  • 106 posts
Posted 14 August 2025 - 07:33 PM
No, long since binned unfortunately.
Just noticed HEL actually sell a kit that does exactly this: https://auto.helperf...nt-subframe-kit
You'd hope they wouldn't sell it if it caused such a dangerous imbalance?
#81 imack
imack
  • 2,379 posts
Posted 14 August 2025 - 07:40 PM
I'd have to swap the discs left to right to eliminate them being the issue. Back in the day when we were replacing front drums on minis, it wouldn't be unusual to have to swap ew drums from one side to the other to eliminate brake unbalance.
I've never used a flat washer to seat taper bearings and never had a problem.
#82 stuart bowes
stuart bowes
  • 2,617 posts
who knows.. as I say I'm no expert or anything, but once you've tried everything else it starts to look that way doesn't it
it could be that the HEL ones are made more rigid in comparison to more standard flexi hose
I guess after the discs start with the banjo bolt and check there's no blockage or anything but presumably it all bled through ok?
Edited by stuart bowes, 14 August 2025 - 07:50 PM.
#83 Hexxeh
Hexxeh
  • 106 posts
Posted 14 August 2025 - 07:58 PM
Yeah all bled through just fine.
I need to re-bleed again to swap the calipers back, so I think I'll pick up another hose and banjo bolt tomorrow from Mini Sport and swap those at the same time, and if it's still persisting, try swapping the discs. I don't really want to run the risk of knackering a fresh set of timkens not using the flat washer, so I'll get one of those tomorrow too just in case.
Edited by Hexxeh, 14 August 2025 - 07:58 PM.
#84 Hexxeh
Hexxeh
  • 106 posts
Posted 14 August 2025 - 10:00 PM
Had a good dig through the tool drawers and found my flat seating washer, so tried swapping discs side to side. Still no difference, pulls to the left as before.
Feels like the only things like must be the hose and the banjo bolt... unfortunately Mini Sports site says they're completely out of front braided hoses. It has been wrong before though, so I'll give them a call in the morning.
I did a bit of research, it seems like the long flexi around the subframe would make the passenger brake slightly less responsive (because of the slight expansion of the braided line) but with a braided line it's very minimal compared to rubber. In any case, that'd be the opposite to the problem I have, where the driver side is the weaker one.
#85 Hexxeh
Hexxeh
  • 106 posts
Posted 15 August 2025 - 11:20 PM
Went to Mini Sport today and got another set of braided hoses (the front pairs were out of stock, so had to buy a full new set of four...) and another banjo bolt and pair of washers for it.
Fitted up tonight and... it seems to have sorted it! I can press on hard enough now to lock the wheels without it trying to throw me into the kerb. It seems the hose itself was faulty from new somehow. I noticed the caliper side fitting is slightly larger (9/16" AF rather than 1/2" AF) so I'll swap the passenger side over too just so they match.
I'd dropped the adjustable pressure limiter for the rears right down to rule them out before, so now each time I go out I'll keep tweaking that until I get the rears dialed in.
Glad to have the car in a state where I can start to drive and enjoy it at last! As always a few things I need to tweak and sort, but nothing that stops it being used in the meantime.
#86 1330RG
1330RG
  • 224 posts
Posted 24 August 2025 - 08:24 PM
Brilliant build thread! Just read the whole thing. Keep up the awesome work.
#87 1330RG
1330RG
  • 224 posts
Posted 24 August 2025 - 08:32 PM
Sorry double post.
Edited by 1330RG, 24 August 2025 - 08:33 PM.
#88 Hexxeh
Hexxeh
  • 106 posts
Posted 29 August 2025 - 03:49 PM
Been away on holiday for a bit, so not too much more progress, but a few bits more to share:
Ordered a replacement high energy ignition module to swap out the standard one I had to switch to while at the dyno. Tried to fit it and... no start. Spoke to Powerspark who suggested to check the gap between the reluctor and the module and make sure it's as close as possible without touching, but no more than 10 thou. It was closer to 25 thou. Moved it as close as can be and it's fired up, probably means the original module may have been fine too I'd just fitted it wrong (I took it out at one point trying to diagnose a problem where it was cutting out).
Apparently it's not so critical on the standard modules, but is on the high energy ones. I am wondering if I've made things worse though, is there a good test you can do at home beyond just using something like a spark gap tester and seeing how far the spark can jump? I'm not sure what difference you'd expect to see there between a standard and a high energy unit anyway.
The indicators never self cancelled properly, one direction they'd cancel almost immediately and the other not at all. The pins on the steering wheel boss weren't in the right location and however you orient the wheel, couldn't be quite correct from what I could see. Drilled a couple new holes for the pins and that's sorted that. I also noted the inner bits of trim at the edge of the spokes on the wheel were a bit loose, so drilled the rivets out, tapped the wheel itself and pulled the leather tight and refitted with screws to clamp the material down. Not perfect, but it'll do for now.
One more thing, something I'd worked on a few weeks ago but never posted the photos here. I know it's not exactly in keeping with the classic vibe, but I really like having Android Auto for maps/music in my cars. I just didn't want it to look "bodged" using a suction phone holder or similar. So, I came up with this:
This wirelessly connects to my phone like a factory install and gives me maps/Spotify. I've tucked it as close to the dash rail as I can within the Z-height constraints in the mounting. It's USB-C powered and there's a 3.5mm aux cable down to the amp. The screen detaches magnetically if you need to remove it for whatever reason:
Printed out of carbon fiber reinforced polycarbonate, so it ought to take the heat no problem.
There's a lot of these screens on Amazon etc for pretty cheap, but the build quality is kinda naff (eg, most of them don't have properly laminated screens like you'd get on a modern phone so they're more prone to glare/reflections). I found a decent quality unit that was pretty neat with small bezels to use for this installation (Amazon link). The mount it comes with is a ball socket which added like 15mm to the depth and made it stick out too much, so I sourced a strong magnet of the right shape/depth to 3D print the actual magnetic mounting adapter as well as the actual mount to the dash.
Used it for a few drives recently and while the audio isn't amazing through the two parcel shelf speakers, it's perfectly good for directions and some music for when you're sat in traffic.
Edited by Hexxeh, 29 August 2025 - 03:51 PM.
#89 timmy850
timmy850
  • 3,600 posts
  • Local Club: MITG
Posted 29 August 2025 - 08:43 PM
The high energy module means it’s capable of delivering more amps from a higher power (lower resistance) coil. If your module is rated to have a 0.8 ohm coil you can also run bigger spark plug gaps which will give a bigger spark
#90 Hexxeh
Hexxeh
  • 106 posts
Posted 30 August 2025 - 12:11 PM
I'm using it with a GCL143 coil, haven't changed the gaps from the 25 thou set on the dyno yet. Got a fresh set of plugs I'll gap to 35 thou and swap in. I just wanted to try to make sure I'd made an improvement and not made things worse...
