Timing Cover Breather
34 replies to this topic
#1 PACINO
PACINO
  • 764 posts
Posted 02 November 2023 - 08:37 PM
Hi guys! I sent the breather of the timing cover to be lowered to leave it flat on one side. Do you think this will be enough to prevent it from hitting the radiator fan?
Thanks in advance.
#2 Gaz66
Gaz66
  • 963 posts
Posted 02 November 2023 - 10:15 PM
Should be ok. They are usually just bashed in locally where the blades would hit.
That's a posh mod considering what came out of the factory 😁
#3 Spider
  • 15,142 posts
Posted 03 November 2023 - 12:05 AM
I either remove the Oil Separator altogether and plug the timing cover or get a small bore timing cover that doesn't have it.
The one on the Flywheel Housing should well be enough. If you find it's not, then you have much bigger issues !
#4 OzOAP
OzOAP
  • 387 posts
Posted 03 November 2023 - 03:40 AM
SPI/MPI breathers have modified covers as std.
Edited by OzOAP, 03 November 2023 - 03:43 AM.
#5 PACINO
PACINO
  • 764 posts
Posted 03 November 2023 - 12:13 PM
Look how the engine turned out. Oil oozes everywhere. It only has one breather, the one on top of the clutch cover. Do you think it's enough Spider?
#6 GraemeC
GraemeC
  • 7,440 posts
Posted 03 November 2023 - 12:18 PM
That looks like a very neglected engine, covered in years of grime and detritus - hard to tell if that due to a crankcase breathing issue or not.
Make sure the exhaust manifold is sealed when you rebuild it too!
#7 gazza82
gazza82
  • 3,019 posts
  • Local Club: TMF+
Posted 03 November 2023 - 01:47 PM
Looks like a poor fitted or badly mullered rocker cover gasket to me
#8 PACINO
PACINO
  • 764 posts
Posted 03 November 2023 - 03:01 PM
The engine runs quite well. Has lost a little compression since being completely rebuilt in 2004 but overall good. It may seem that I don't take care of it or that I have abandoned it but that is not the case. I clean that area with spray from above because I don't have a 'lift' and after three months it is again full of sweaty oil. Every year when I pass the M.O.T they tell me that carter low side and the lower rear part of the engine have that bad appearance. I think internal breathing is bad. And now that I'm going to rebuild it, I'll add 2 more breaths; -Timing cover and rockers cover- and I hope this improves the ventilation a lot.
#9 stuart bowes
stuart bowes
  • 2,246 posts
Posted 03 November 2023 - 03:10 PM
I was going to ask if the rocker cover has a breather on it because clearly there's something going on there with a leak isn't there
whether thats caused by pressure build up or what obviously no idea
#10 PACINO
PACINO
  • 764 posts
Posted 03 November 2023 - 03:13 PM
Front side:
#11 whistler
whistler
  • 1,818 posts
Posted 03 November 2023 - 04:27 PM
I think most of that oil down the back is as already said by Gazza82 caused by rocker cover gasket leak and exhaust manifold leakage.
If you block up the TC breather you could revert to a rocker cover breather to add to the clutch cover breather.
#12 KTS
KTS
  • 2,462 posts
Posted 03 November 2023 - 05:06 PM
as Spider alluded to above, if the oil is being forced out of the engine due to crankcase overpressure then you have to address the cause of that rather than just try and mitigate against it by fitting more breathers
as others have said, i'd be taking a close look at the rocker cover seal - what type of gasket are you using ?  is it and the surfaces it seals against in good condition ?
#13 PACINO
PACINO
  • 764 posts
Posted 03 November 2023 - 11:36 PM
Cheers Gaz66
#14 PACINO
PACINO
  • 764 posts
Posted 03 November 2023 - 11:37 PM
Thank you OzOAP
#15 PACINO
PACINO
  • 764 posts
Posted 03 November 2023 - 11:39 PM
Thanks for your answer GraemeC
    Google (1)
