Water pump fitment.
Posted 17 November 2006 - 01:26 PM
Fitting a water pump tommorow on 1992 998cc. Part has arrived with gasket which is fine, just wanted to know if theres any pre-fitting proceedures I should do like greasing up or WD40 in the moving part.
Many thanks
Posted 17 November 2006 - 01:29 PM
i would put a very light smear of multipurpose grease around the gasket though, just helps it seal it up properly.
Posted 17 November 2006 - 01:30 PM
Posted 17 November 2006 - 01:41 PM
Right they have to be torqued to 17lb/ft
Edited by Retro_10s, 17 November 2006 - 01:41 PM.
Posted 17 November 2006 - 03:13 PM
Posted 17 November 2006 - 03:20 PM
You can get one from Argos for £15 but I dont think it goes as low as 17 lb/ft.
No one in your club got one that you can borrow for two minutes to nip the bolts up ?
When doing bits like this it is really important to use it to get the seal correct, too tight and you squish the gasket too much and it wont seal properly, too loose and it wont seal properly and will work its way loose.
Posted 17 November 2006 - 03:40 PM
Like £15 won in a test with a load of others in a mini mag a little while back.
http://www.machinemart.co.uk/
edit
think its this one:
http://www.machinema...asp?p=040212720
Edited by Big_Adam, 17 November 2006 - 03:42 PM.
Posted 17 November 2006 - 04:03 PM
these are all the settings for a mini 998cc engine that i have got out og my haynes manual dont know weather it helps or not but here they are
Torque wrench settings
......................................................................Nm........
...lbf ft
Auxiliary drivebelt tensioner bolt ………………………...22……………..16….
Camshaft retaining bolts …………………………………......11……………...8…..
Camshaft sprocket nut……………………………………........90……………..66…
Connecting rod big end nut……………………………….......45……………...33….
Crankshaft pulley bolt……………………………………........150…………….111..
Cylinder head nuts
Stage 1……………………………………………………................34……………..25
Stage 2…………………………………………………….................68……………..50
Engine left hand plate bolt………………………………….......11……………..8
Engine mountings
Left hand engine mounting bracket to transmission……….25……………18
Left hand engine mounting to mounting bracket…………....22……………16
Left hand engine mounting to sub frame…………………........22……………16
Right hand engine mounting to flywheel housing cover …18……………13
Right hand mounting to subframe…………………………...........22………..….16
Engine lower tie bar to subframe…………………………............40……………30
Engine lower tie bar to transmission bracket……………….....40……...…….30
Engine upper tie bar to bulkhead…………………………............22…………....16
Engine upper tie bar to cylinder head……………………...........22…..………..16
Flywheel centre bolt………………………………………...................150…….…….111
Flywheel housing bolts……………………………………...................25…………...18
Flywheel housing cover bolts…………………………….................10……………7
Main bearing bolt…………………………………………......................85…………....63
Oil pressure relief valve nut………………………………................60……………44
Oil pressure switch………………………………………......................25………...….18
Oil pump bolts…………………………………………..…......................11……………8
Oil temperature sensor…………………………………..................…60………..…..44
Rocker cover bolts………………………………….………....................5………….…4
Rocker shaft pedestal nuts…………………………….............….....25………..…..18
Timing chain tensoner bolt………………………………...................22……………16
Timing cover bolts………………………………………........................16………...….12
Transmission casing to engine…………………………...................8………….…6
Water pump pulley bolts…………………………………....................10………..…..7
*Use a new bolt
hope this helps
Ryan
Edited by minimad998, 17 November 2006 - 04:04 PM.
Posted 17 November 2006 - 04:25 PM
Posted 18 February 2007 - 07:52 PM
Im changing my water pump on my MG METRO TURBO ENGINE.
I didnt know u had to tighten them like that. ive not got a Torque Wrench. how does it work, do u set it to a setting, then as your tightening the nuts, does the tool sort stop tightening. thanks....
Which one should i buy.
Thanks..
http://cgi.ebay.co.u...e...p;rd=1&rd=1
Edited by Mark1275GT, 18 February 2007 - 08:23 PM.
Posted 18 February 2007 - 11:31 PM
Posted 19 February 2007 - 12:17 AM
that tool zone one is similar to my own one...........which I fuggin hate. I can't set the thing as it's weird. I winds in 12's so it messes with my mind.
Posted 19 February 2007 - 01:09 PM
A torque wrench is a spring item, as you wind to the correct setting (writen on the body of the tool) a sping hold a sort of clutch. When the twisting force overcomes the spring (IE when the nut is torqued up) the wrench will click or go. Digital ones vibrate or bleep.
So what would be the best one to get as an all rounder. as i guess i better tighten the nuts on my water pump proper.
Could someone give us a link on the best one.. thanks alot
Posted 19 February 2007 - 03:37 PM
