Specialist Components 7 Port Wiring Loom
16 replies to this topic
#1 Professor Simon Peach
    Just On Tickover
  • 7 posts
Posted 18 November 2023 - 06:03 PM
Hi,
Has anyone got a wiring schematic for SC 7 port? Mine arrived wrong and I need to confirm my connections. I have 3 wires going to the coil pack which has 4 pins. A photo of this and the TPS connector would be great.
I've searched all day but nothing found.
I nearly have the car finished and this would be very helpful.
Cheers,
Simon
#2 IronmanG
IronmanG
  • 1,135 posts
  • Local Club: Box hill. Lsmoc member
Posted 18 November 2023 - 09:19 PM
This ok?Attached File  Screenshot_20231118_212316_Gallery.jpg   15.04K   2 downloadsAttached File  Screenshot_20231118_212323_Gallery.jpg   21.59K   3 downloads
Edited by IronmanG, 18 November 2023 - 09:25 PM.
#3 IronmanG
IronmanG
  • 1,135 posts
Posted 18 November 2023 - 09:20 PM
Although the amount of problems I had with SC who is to say they are always the same!
#4 PoolGuy
PoolGuy
  • 739 posts
Posted 18 November 2023 - 10:01 PM
OP, are you using the Mini coil pack (4 terminals) rather than the Ford pack (3 terminals) and the Magnetti Marelli tps?
Edited by PoolGuy, 18 November 2023 - 10:11 PM.
#5 IronmanG
IronmanG
  • 1,135 posts
Posted 18 November 2023 - 10:10 PM
Sorry. Not a clue
#6 Midas Mk1
Midas Mk1
  • 5,645 posts
  • Local Club: S.U.N.M.C
Posted 19 November 2023 - 01:24 AM
They have pin outs for all their ecus on their website, helped me on diagnosis over the summer. All you need is an ecu pinout.
#7 Professor Simon Peach
    Just On Tickover
  • 7 posts
Posted 19 November 2023 - 07:21 PM
Thanks all. The coil pack and TPS were swapped on the original loom. I was ablecto confirm this on another 7 port near me.
I have 4 pin connections on the coil but 4 pin connector with 3 wires. I think I've fixed it now.
My triggerwheel is not triggering but it may be a software setup thing.
I was on it all weekend. I'll go back tomorrow
#8 Professor Simon Peach
    Just On Tickover
  • 7 posts
Posted 19 November 2023 - 07:22 PM
#9 Professor Simon Peach
    Just On Tickover
  • 7 posts
Posted 19 November 2023 - 07:23 PM
Would I be better with the 3 pin?
#10 PoolGuy
PoolGuy
  • 739 posts
Posted 19 November 2023 - 07:24 PM
Not necessarily, but if you're using the Mini coil pack I can give you the wiring info.
#11 Professor Simon Peach
    Just On Tickover
  • 7 posts
Posted 19 November 2023 - 09:17 PM
Yes please. That would be handy.
#12 PoolGuy
PoolGuy
  • 739 posts
Posted 20 November 2023 - 07:46 AM
On the Mini coil pack, pins 1&2 are the coil drivers and 3&4 are for the 12v feed.
#13 Steve220
Steve220
  • 4,896 posts
  • Local Club: BMC
Posted 20 November 2023 - 03:52 PM
I think it has been resolved, but that coil doesn't need 4 pins on the application.
1 - Coil bank 1
2 - Coil bank 2
3 - 12V switched ignition.
(those aren't the pin numbers, just what they're used for. I'll look later for the pin output).
Edited by Steve220, 20 November 2023 - 03:53 PM.
#14 Professor Simon Peach
    Just On Tickover
  • 7 posts
Posted 28 December 2023 - 08:26 PM
Thanks all. I swapped the coil for a 3 pin type and swapped the trigger wheel and the car is running. I have to set up the timing I think. It's hard as I cant be 100% sure of TDC.
I'm going to bring it to the rolling road soon. Hopefully it'll run better as it is a bit snorty.
Edited by Professor Simon Peach, 28 December 2023 - 08:27 PM.
#15 IronmanG
IronmanG
  • 1,135 posts
Posted 29 December 2023 - 12:09 AM
Where are you based
