![Photo](https://secure.gravatar.com/avatar/6728e923de1660b36fd7f82ce7a57b99?s=100&d=https%3A%2F%2Fwww.theminiforum.co.uk%2Fforums%2Fpublic%2Fstyle_images%2Ftmf%2Fprofile%2Fdefault_large.png)
Won't Start.
Posted 21 November 2023 - 04:43 PM
Battery reads 12.6v and I've swapped the relay and still nothing.
Am I safe to assume starter has failed?
Posted 21 November 2023 - 05:06 PM
Don't know what year this Mini is. Mine has an inertia pinion starter motor. But I had a Metro once that did this. It used an electric solenoid to engage the pinion which sometimes got stuck. If you give the pinion casing a sharp tap with a suitable bar (a socket set extension bar for example) and a medium-sized hammer it might free it up. But it will probably happen again.
Posted 21 November 2023 - 05:39 PM
Is this a sign I need a new stater?
Posted 21 November 2023 - 05:43 PM
Posted 21 November 2023 - 06:05 PM
Always worth a try.. if it is broken and not working then can not break it further.....
Posted 24 November 2023 - 09:07 AM
Got it started after about 5 minutes of hitting it with a bar.
I never got past the hitting it stage before some toe-rag stole the Metro (it was an MG). It was only an intermittent problem or it might have been a better security feature.
Posted 25 November 2023 - 12:39 AM
And third; The starter motor must rotate strongly. Disassembling it and cleaning the inside with a brush and gasoline renewing the contact point brushes is essential.
Posted 27 November 2023 - 08:03 AM
It used to happen a lot to my Allegros, but they were not pre engaged
If you clean the Bendix gear regularly you will avoid the no start situation
I used to carry an engineering hammer to tap the motor if it was recalcitrant
Posted 05 December 2023 - 05:31 PM
I think it's always been like that so surprised it's only happened once tbf
