Rear Brake Spring Circlip
Best Answer croc7 , 28 December 2023 - 12:03 AM
Thanks for the help.
EDIT: I read all of the replies and the post from Shifty, all very helpful. In the end, I decided to let a friend do it for me, he has a lift which affords better access rather than me rolling around under the car on jack stands.
Go to the full post#1
Posted 26 December 2023 - 07:41 AM
Posted 26 December 2023 - 08:01 AM
Hey Jerry,
Merry Christmas mate. Honestly, I can't say I've ever had trouble doing them. I just use a small bladed screw driver, get one 'ear' on the end of the clip in place, it won't seat in the groove though as it'll be at too much of an angle, then using the screw driver, lever over the middle ear, then the last one, finally giving each ear a good pressing down to be sure they are all seated in the groove.
If you find doing it on the ground awkward, there's very little work involved to remove the backing plate off the Trailing Arm and doing them on the bench. If you do end up doing them that way, you could also pull the clevis pin for the handbrake lever, then build up the entire brake on the bench.
Posted 26 December 2023 - 08:16 AM
Merry Christmas to you and best for the New Year. May the road rise up to meet you.
Posted 26 December 2023 - 08:37 AM
There's a cunning trick with a pair of mole grips to hold the cylinder in while doing the circlip. Let me see if I can find it.
Posted 26 December 2023 - 08:56 AM
I recommend the mole wrench technique that has been mentioned.
Posted 26 December 2023 - 10:22 AM
As Chris says. Never had an issue using a screwdriver.
Posted 26 December 2023 - 10:59 AM
Canna make life easy for yourself...
Also recommend the vice grips way...
The satisfaction after will be worth it i promise....
Posted 26 December 2023 - 11:20 AM
There is a tool for it
It's tool 14 on the Mini Spares website
http://minispares.co...|Back to search
Edited by greenwheels, 26 December 2023 - 11:21 AM.
Posted 26 December 2023 - 01:53 PM
or from ebay and save the carriage cost
https://www.ebay.co....:Bk9SR_yAsOaUYw
(i have no affiliation etc)
Edited by stuart bowes, 26 December 2023 - 01:54 PM.
Posted 27 December 2023 - 02:14 AM
Posted 27 December 2023 - 09:38 AM
get the correct tool and it is a breeze, spent years filing leading edge and using pipe pliers but the tool makes it so much easier
Edited by coopertaz, 27 December 2023 - 10:09 AM.
Posted 27 December 2023 - 09:50 AM
Good pictures of how to use it on that ebay site.
Posted 27 December 2023 - 12:45 PM
Or it’ll be loose
Posted 27 December 2023 - 02:41 PM
