Hi all,
Can’t find the clearances for this bushing - I’ve seen people mention machining new bushes to .001”. What’s the upper wear tolerance please?
Thanks!
Posted 29 December 2023 - 12:46 PM
Hi all,
Thanks!
Posted 29 December 2023 - 06:36 PM
I don't have any Service specifications for them but generally set the running clearance to 0.0009 to 0.001". I would suggest an upper wear limit of 0.0012" to maybe 0.0015"
I wouldn't get too hung up on the clearance though, what's important here is that there's no taper in the bush as that'll cause it to jump out of Reverse when under load.
Posted 30 December 2023 - 11:04 AM
Thanks Spider. The ends of the bush are outside that upper range. Don’t have a small bore guage to measure the centre, but for the minimal extra hassle, we’ll replace the bush. Ta
