Bearing Puller Set
3 replies to this topic
#1 Gaz66
Gaz66
  • 961 posts
Posted 03 January 2024 - 04:47 PM
Can anyone recommend a good puller set?
Preferably one that can do all gearbox/transfer case jobs. 👍
#2 nicklouse
  • 18,696 posts
Posted 03 January 2024 - 05:56 PM
Early or late gearbox?  The correct ones are best. The only tricky ones are in the transfer case. And any blind hole puller set with some mods can work.
#3 Gaz66
Gaz66
  • 961 posts
Posted 03 January 2024 - 06:45 PM
At the moment A+ boxes.
I would have thought from a puller point of view they would be all the same?
#4 Spider
  • 15,123 posts
Posted 04 January 2024 - 10:41 AM
I'm not sure a 'set' would be the most economical way to go here. It will almost certainly have a lot of pullers & adaptors that you just don't need for doing Mini Gearboxes. If you see yourself using it for other jobs then sure. For me doing work on Minis and Mokes, I saw there was only 3 pullers I needed, so that was all I ever bought.
It may be too that a set could work out cheaper than 'loose tools' but usually buying them individually you can get a better quality. The one thing I learned early on that was more frustrating than not having the tool was poor quality tools that would let me down when I needed them.
