Hi all,
i just want to know if i can fit Gaz standard mini shocks in coilover brackets? or are they to short?
Got a vtec allspeed frame that hit the shock and don't want to run coilovers.
Ant
Fitting Gaz Standard Mini Shocks To Coilover Brackets?
mini van ant
, Jan 27 2024 07:59 PM
2 replies to this topic
Posted 27 January 2024 - 07:59 PM
Posted 27 January 2024 - 08:02 PM
What do you mean by coilover brackets?
what springs are you going to run?
what is the difference in open and closed lengths between the one designed for the frame and the Gaz ones? Gaz do more than one length.
Posted 27 January 2024 - 08:42 PM
They are standard height gaz shocks not the lowed ones.
When fitting coilovers you need brackets to replace std mini top mounts.
The std mini shocks hits the subframe allspeed advised spacing top mount out or fitting coilover brackets.
I am not fitting coilovers so just want to know if std shock work with coilover brackets as it needs to be spaced out to far to clear.
