Crankshaft Clutch Oil Seal And Dust Seal
3 replies to this topic
#1 Myminiproject
Myminiproject
  • Just Joined
  • 22 posts
Posted 01 February 2024 - 07:58 PM
Hi all,
Can anyone let me know how much the crankshaft clutch oil seal should be pushed in? There's a slight bevel and I've pushed it to be level with that bevel (huh! That rhymes :) see picture.
Also, is the dust cap supposed to not push all the way in? It sits at a slight gap of 1-2 mm from the clutch housing, see picture.
Thank you in advance for your help.
Attached File  IMG_8858.jpeg   35.83K   0 downloads
Attached File  IMG_8857.jpeg   31.65K   0 downloads
#2 Spider
  • 15,136 posts
Posted 01 February 2024 - 08:10 PM
That seal location to me looks OK, as long as it's square, it should be fine.
I usually fold over a sheet of paper, tear it in 2, place a piece either side of the primary gear, then push the dust cover on to the paper slips, then pull them out.
#3 Myminiproject
Myminiproject
  • Just Joined
  • 22 posts
Posted 02 February 2024 - 11:26 AM
Thanks as always Spider. Trying to imagine this paper folding exercise :) so the folded pieces go between the dust cover and the clutch cover/seal? In which case my dust cover is too far out and needs to be pushed further towards the seal, that is, the distance needs to be two paper thicknesses - hmmm, hope I got that right!
Afterthought: I guess by the time the flywheel clutch assembly is on and torqued up, the dust cover will be pushed into the right location.
MMP
Edited by Myminiproject, 02 February 2024 - 11:28 AM.
#4 Spider
  • 15,136 posts
Posted 02 February 2024 - 05:58 PM
MMP
So put another way, I set them at 2 paper thicknesses from the cover. I've never found any factory info on where to set them, but being a dust excluder and the dust being fine, I figure the closer, the better, in fact, I'm sure if they were fitted touching the cover, they'd be fine, but I also figure, if there's a big gap, then it's effectiveness would be greatly reduced.
I'll add though, I wouldn't fret too much over it, these only appeared in 1979, prior to that, none were fitted (or even available) and while I do fit these on every build, I can't say I can't say I've ever seen an issue from dust getting in to the seal either.
