Hi,
looking for suggested solutions, the LCB 0.5mm thinner and not sealing when all tightened up.
thanks in advance
Posted 18 February 2024 - 07:11 PM
Hi,
thanks in advance
Posted 18 February 2024 - 07:16 PM
Stepped washer’s
Posted 18 February 2024 - 07:19 PM
Is that a thing - can you buy them
Posted 18 February 2024 - 07:41 PM
Posted 18 February 2024 - 07:47 PM
For that sort of difference, you can put a bend through the middle of the Washers, when you tighten them up, just be sure the 'dipped' parts of the washers are what's contacting the flanges. I've done this a few times.
Posted 18 February 2024 - 07:56 PM
That’s a good idea spider, sounds easier that filing off 0.5mm accurately
Posted 18 February 2024 - 08:31 PM
or you could file the back of the inlet manifold tabs (not the gasket face) so they are the same thickness as your LCB
Posted 19 February 2024 - 01:34 PM
That's what I always do. That way you don't have to worry about alignment of the stepped washer when tightening up.
Posted 19 February 2024 - 05:24 PM
In preparation for the day that things go wrong .................. while you are about it, file off the bottom of the inlet tabs / lugs, so that you only have to loosen the manifold nuts to lift the carb off. Do the same with the top of the exhaust tabs / lugs, (but I have found it best to replace the end studs with well Cupasliped bolts) so that you can easily lift the head off.
Posted 13 August 2024 - 05:25 PM
20240813_165852.jpg 25.44K
1 downloadsPosted 13 August 2024 - 07:16 PM
Posted 13 August 2024 - 11:12 PM
Edited by Chris1275gt, 13 August 2024 - 11:13 PM.
Posted 13 August 2024 - 11:42 PM
Just trial fitting my manifolds to the head and I have the same issue. The inlet manifold is thicker than the exhaust so I guess the files will need to come out.
I'm also replacing the studs with hex headed screws but that is another issue ... none of my Allen keys or hex sockets fit. 3/16" too small, 1/4" too large. (Tried metric ones too) Looks like a 7/32" is required!
Also had to put the spacer between the manifold and abutment plate or that pushes onto the centre pipe of the exhaust. (Maniflow)
That looks like a mini/metro inlet manifold and newer exhaust manifold?
Mine had approximately 4mm difference between the two so I had someone make up some stepped washers from some round bar
Posted 14 September 2025 - 11:06 AM
