1 / 2 looks OK, 3 / 4 looks miles out from what I can see in your pic.
Either the Fork is wrong, the dimple in the Shift Rod is in the wrong place, or both.
Just as a check here, if you remove the locating screw from the Fork (allowing it to float), does the Main Shaft then 'seat' OK in them ?
Yes, without fixing the forks on the rod the main shaft sits fine.
Additionally if I put on only one synro hub the shaft will rotate freely >>> https://photos.app.g...1MM5jjhZt3GcK2A
When I put on BOTH syncro the shaft becomes tight because the mis-alignment.
20240211_154028.jpg 53.12K
0 downloads
I marked the position of a god fork on the rod, you can see how "off" it is
20240217_102825.jpg 65.7K
0 downloads
Yesterday I found a good-looking pair but the 1/2 fork is very close to the wear limit (0,38mm) and I am not so happy with that.
20240211_161947.jpg 32.58K
0 downloads
