Hi.
I have a swifttune 1275* engine in my shiny new* mini, done about 2000 miles. I just got the car and done maybe 300 miles with no issues. After sitting in a bit of traffic on the Mway I found I could not accelerate without misfiring, it got worse. Any attempt to give it throttle and it way seriously frogging like a first time driver in the wrong gear. Idle was fine. After stalling out, it would not restart. Experienced RAC checkd the sparks, fuel supply, tapped the float chambers (dual SUHS4), checked the dizzy and rotor and plugs. 2 wet plugs, 2 dry 1&3 2&4 go figure. Engine will not start.
Later inspection revealed one if the float chambers has a lot of play and needs tightening back on to the body of the carb - but would that be an issue ?
I've got new plugs, leads,coil and some Carb gaskets on order, but if anyone has any ideas on this, please chirp in.
I should also mention a minor coolant leak somewhere around the radiator which I could not see the source, so put some rad weld type in. New radiator is on order too.
Thanks.
Edited by Traut, 20 February 2024 - 08:27 AM.
