Oil.pump
Posted 21 February 2024 - 09:38 PM
Whilst it's apart I'm changing the oil pump.
I have ordered minispares GLP138, but, I've seen recommendations to buy an oil pump that's modified etc.
What's your thoughts on the minispares item and will it be ok to use?
Car.doesnt get a hammering etc
Posted 21 February 2024 - 10:05 PM
Strip it clean it at a minimum.
Posted 21 February 2024 - 10:10 PM
Posted 21 February 2024 - 10:25 PM
I always use GLP110MS. It has a very much higher flow rate, but I now always use it as I have had issues with the GLP138.
The oil pump is the heart of the engine and for peace-of-mind it's always worth changing it when the engine is down.
Posted 21 February 2024 - 10:45 PM
Even though its brand new?
Yes. The amount of crap that is found in them is horrendous.
Posted 21 February 2024 - 11:37 PM
The GLP138 is all you need here.
As Nick suggests, a good idea to open them up and at least inspect.
Posted 22 February 2024 - 06:26 AM
Always!!! And check clearances.
Posted 22 February 2024 - 04:19 PM
Inside the box is a leaflet saying that the pump is engineered to very fine working tolerances and they are pressure and flow rated by quality control.
Always a bit sceptical when you receive a different part number to what was ordered.
Posted 22 February 2024 - 06:01 PM
I've just bought an AC Dodd zero tolerance, on similar advice on what's left by the machining........
Posted 22 February 2024 - 08:21 PM
AC Dodd pump is a quality product
Posted 22 February 2024 - 09:07 PM
Posted 22 February 2024 - 10:32 PM
My old pump was held on with 4 bolts and the cover can't be removed
Yes it can.
