How Tight? Belt Drive Vernier Bolts.
2 replies to this topic
#1 ItsNotDads
ItsNotDads
  • 24 posts
Posted 23 February 2024 - 02:53 PM
Hi all,
Cam timing is set.
New belt and seals fitted to a belt drive kit that came without paperwork. The sprocket is locked with 6 x M5 bolts. How tight do they need to be? They are currently nipped up by hand. We’re nervous of going too tight and stripping out the threads!
#2 KTS
KTS
  • 2,272 posts
Posted 23 February 2024 - 03:02 PM
not much by the look of it
https://monsterbolts...ew-torque-specs
edit :  might be worth a bit of loctite on them for peace of mind
Edited by KTS, 23 February 2024 - 03:05 PM.
#3 nicklouse
  • 17,946 posts
Posted 23 February 2024 - 06:04 PM
First question is wha5 are they screwing into? That has an affect. What size are they? That can give you a standard figure for a certain material.
what does the manual say. That will be the correct info for the thread type and the material.
