Missfire On Start Up
Posted 24 February 2024 - 12:44 PM
Ive got my mini sprite running after 2 months.
Ive had new plugs leads /coil /dizzy /distributor/battery/alternator.
I’ve turned dizzy enough to get going and runs fine when warm.but still slight missfire on initial start up.is there a way to stop this.thanks all.you’ve been a great help so far
Posted 24 February 2024 - 05:45 PM
Is there more info on your ignition setup?
It could be ignition or fuelling, but it's best to start fault hunting with the ignition first. Do you have a timing strobe and/or dwell meter?
Posted 24 February 2024 - 06:36 PM
Hi all.
Is it a single cylinder misfiring, or a general hesitancy?
Posted 24 February 2024 - 10:22 PM
And it only pops on intial start so i can’t tell if its single pot or not.fuel is no issue as runs fine .
I think just needs tweek on timing as i only guessed by sound when turning dizzy.
Oh and how do you check timing with strobe.excuse ignorance but i had mini 35 years ago so technical is not my strong point.I think i did well just to get it started with many bashes and cuts to hands lol.
Posted 24 February 2024 - 11:50 PM
Clean, or new plugs, gapped correctly, fresh fuel, don’t just warm up and idle, warm up and drive to temperature.
Posted 26 February 2024 - 01:20 PM
The timing light "freezes" the position of the mark and allows you to line it up with the other marks. Steveson motor co has an ok video (not perfect)Hi all i dont have strobe or dwell
You really need to get a timing light, it is not optional.
Edited by 68+86auto, 26 February 2024 - 01:20 PM.
Posted 26 February 2024 - 02:27 PM
Will get timing light and go from there.
Top info cheers all
Posted 27 February 2024 - 06:08 AM
Thanks all
Top info cheers all
If you can get a timing light with advance it will be best.
