Rear Drums Won't Go Over New Pads.
Posted 25 February 2024 - 04:11 PM
The handbrake is off, but noticed that the handbrake 90 degree pivot point in the drum is solid. Should the two bits of metal pivot slightly at the point?
Posted 25 February 2024 - 04:26 PM
Posted 25 February 2024 - 05:38 PM
Yes.
normally the problem is the shoes are not central. Get the handbrake lever moving and back the adjuster right off.
Posted 25 February 2024 - 06:46 PM
Brake SHOES need to be central. Also remember the brake adjuster is on a square so could also be mid turn..
May also need the lever adjustment tweaked to get the space for new shoes. Were the old ones really bad?
Edited by bpirie1000, 25 February 2024 - 06:47 PM.
Posted 25 February 2024 - 08:19 PM
Posted 25 February 2024 - 09:38 PM
If all else fails double-check you have the right drums. I have been sent the wrong ones before (Moss Europe were then very good about replacing them).
Posted 26 February 2024 - 04:36 PM
Check also you are not fitting front shoes to the rear, as I done once...
