rocker cover and thermostate Gasket Glue
Posted 19 November 2006 - 10:52 AM
Posted 19 November 2006 - 11:20 AM
Posted 19 November 2006 - 12:53 PM
Posted 19 November 2006 - 01:00 PM
you don't use any sort of 'glue' when fitting them... especially the rocker cover which you will have to remove to adjust tappets etc...
yep it's not needed if you install the gaskets correctly and torque trhe bolts to the right settings.
I've seen some people put a smear of superglue on the rocker gasket to the rocker cover to hold it in shape,... i've never had to do that though.
Posted 19 November 2006 - 01:08 PM
Posted 19 November 2006 - 01:19 PM
Posted 19 November 2006 - 01:23 PM
Posted 19 November 2006 - 01:37 PM
don't you use that blue stuff ??
there shouldn't be an need for it if you clean the surfaces the gasket sits on properly. And yes... always use a good quality 'rubberised' cork gasket. plain cork is ok but fatigues faster, the proper one has a rubber compound in it too,.. creating a tighter, more secure seal and lasting longer before it needs tightening down a bit lol.
Edited by Retro_10s, 19 November 2006 - 01:37 PM.
Posted 19 November 2006 - 01:45 PM
I went to minispares yesterday and got one theredon't you use that blue stuff ??
Got my decount too
Nver thought about adjust the tappets. that good thing to do while im there then ?
I guess it tells u how in the Haynes which im still waiting for from ebay. 2nd hand one
Posted 19 November 2006 - 02:39 PM
i think the Haynes manual tells you to do it a strange way, in mini-world (i think) it said put the car in gear, jack up the passenger side front wheel and turn the wheel by hand to turn the engine. i always found this to be a good way to do it.
also a tip: when you buy the gasket from "whoever" they tend to hang it on a hook and it will close together in the middle making it a pain to fit (i guess this is why you want to use the glue).
it's best to buy the gasket at least a month before you need it and store it around a box or container (clean bottle of oil works well) to reform it into it's proper shape. it makes thing a lot easier.
Edited by THE ANORAK, 19 November 2006 - 02:45 PM.
Posted 19 November 2006 - 02:42 PM
Posted 19 November 2006 - 02:56 PM
Yeah it is abit like that :'(
Ill do what u said.
Plus, dont want to go of the subject.
But is it worth adjusting the tappets ? whats the reason for adjusting them. sorry if this has been asked. but cant found this on the search :'(
Could someone send me a link on this, some sort of guide. thanks
Posted 19 November 2006 - 04:12 PM
As for the how 2 guide on adjusting the tappets, well I know I’ve posted one up a few times (goes off searching for it, back in a bit.)
*Edit*
Found it, at last…
‘‘Idiots guide to tightening tappets"
Edited by 1984mini25, 19 November 2006 - 04:21 PM.
Posted 19 November 2006 - 07:13 PM
