Hi All, First Mini
Posted 05 March 2024 - 09:33 AM
Posted 05 March 2024 - 09:55 AM
I certainly would take a box at a time and work through things and write a list of bits you have and work out when you will need them.. interior last and subframes/suspension first kind of thing..
Sounds like you will have loads to clea up and inspect... small bits of work alot of the time make so much difference.
Posted 05 March 2024 - 11:27 AM
diagrams on minispares can help when trying to identify parts and work out what bolts go where
and the haynes / workshop manual obviously
Edited by stuart bowes, 05 March 2024 - 11:29 AM.
Posted 05 March 2024 - 01:23 PM
Posted 05 March 2024 - 01:32 PM
Posted 05 March 2024 - 01:42 PM
Looks pretty sound from what you can see in the pictures. my advice would be major on the body work to start with whilst enthusiasm is high. Body work is usually the part of the project that stalls it. Good luck with it and let us see some pictures as you progress
Posted 08 March 2024 - 07:12 PM
Allan
Posted 08 March 2024 - 09:48 PM
I have noticed the bulkhead looks to be modified. Any ideas why ?
Posted 08 March 2024 - 10:52 PM
usually I believe the trick is to weld in a battery box to make space for bigger carbs like the weber dcoe, that may be what they've done there
any info on the spec of the engine?
Edited by stuart bowes, 08 March 2024 - 10:54 PM.
Posted 10 March 2024 - 09:51 AM
Allan
Posted 12 March 2024 - 12:52 AM
Gonna rip the over sills off first and see what's lurking underneath. Inner sills from inside the car seem solid and rust free. The cars been in storage since oversills were fitted so hoping it's not too bad.
Posted 08 April 2024 - 08:09 AM
76306a1b-e29c-4abf-ada9-5f4b976ce912.jpeg 40.81K 6 downloads e983d3b4-a490-41ce-8602-bb6a0d622847.jpeg 64.87K 3 downloads eca25e80-dd53-466f-84f6-c76788abcfb1.jpeg 50.68K 3 downloads
Edited by Gar37, 08 April 2024 - 08:12 AM.
Posted 08 April 2024 - 08:38 AM
not normal at all - looks to me like the cylinder head has been massively skimmed which is why the pistons have been machined to allow room for the valves to extend into the bores when they open
I assume it's been done to reduce the combustion chamber volume, but does look pretty extreme
Posted 08 April 2024 - 10:00 AM
Just trying to see what I have/ don't have. It's just a big jigsaw for now.
Posted 08 April 2024 - 10:06 AM
it appears there's been quite a lot of effort put in to the engine, so might be interesting to see whether the block and crank are anything special...
