What Oem Radio + Aux In Or Bluetooth?
3 replies to this topic
#1 GermanMoreno
GermanMoreno
  • 206 posts
  • Local Club: Mainly Minis Montreal
Posted 05 March 2024 - 07:43 PM
Wondering if any of the original mini radios from rover, had the option of aux in ? or bluetooth adapter? i want to retrofit one unit but I am uncertain which one would work? New aftermarket units look terrible!
#2 Tornado99
Tornado99
  • 750 posts
Posted 05 March 2024 - 09:52 PM
Not sure on OEM AUX in jack presence, but this guy shows how he modified the OEM radio with a Bluetooth unit:
Alternatively, you can always use one of the many Bluetooth FM transmitter units available everywhere & cheap as chips...then just tune your radio to its "channel" frequency and listen away.
#3 68+86auto
68+86auto
  • 996 posts
  • Local Club: Queensland Mini Car Club
Posted 06 March 2024 - 05:57 AM
Yes, modern radios look garbage. It took me quite a while to find a remotely period correct radio for my mini.
I don't believe any of the factory radios had an "Aux" in however I think some did support a CD changer. the CD changer input can likely be used as an AUX in with some work.
You could just modify the radio with a connector or Bluetooth. As long as the radio has a potentiometer not a rotary encoder, it is pretty easy to find where to interrupt the signal.
Edited by 68+86auto, 06 March 2024 - 05:57 AM.
#4 Steam
Steam
  • 816 posts
  • Local Club: Victorian Mini Club
Posted 06 March 2024 - 06:32 AM
Using a reasonable quality bluetooth fm transmitter you can have phone connectivity and usb music and charging. The lesser quality ones can be unreliable.
