I've spent far too long trying to attach a bleed pipe to the clutch slave cylinder. So little access! Car is a YKG2S2 mk1 cooper S 1275. Does anyone have any bright ideas?.
Bleeding Clutch
Posted 06 March 2024 - 09:04 PM
Posted 06 March 2024 - 10:13 PM
Extend the bleed point to the front of the engine.
Posted 06 March 2024 - 10:34 PM
You don't really need a bleed pipe. Just get someone to build pressure with the pedal and hold it there. Open the screw and quickly close it again. Repeat a few times until the clutch works properly. The pipe is a luxury that helps you see there are no bubbles. But whether you can see them or not doesn't really alter the procedure.
Posted 06 March 2024 - 10:39 PM
I would say that a Mk1 Cooper S would be relatively straightforward compared to the latest model (Mk7?) - I don't have particularly flexible fingers but I would take the former over the latter if I had to bleed one
Posted 07 March 2024 - 12:25 AM
Posted 07 March 2024 - 02:47 AM
https://www.toolmart...rome-k8145.html
You can also remove the slave cylinder from the clutch housing and put it in a plastic tub to save making a mess
Posted 07 March 2024 - 11:39 AM
i usually get someone to pump pedal and just put a cloth under bleed nipple to catch fluid so little needs bleeding compared to brakes
Posted 07 March 2024 - 05:34 PM
Then you will know the pipes are all good.. also never rule out the slave cylinder. Make sure it will move freely..
