Well what started out as a bit of an interior tidy up has tuned into a complete refurbishment!
I want to move the speakers from the dash to the rear (below the seats). I also need to wire in heated seats although I may fit the switches to the seats and wire them from the battery via a relay.
I also already have a wire running along the side below driver's door for the electric fuel pump.
Ideally I don't want to see any wires or have any unsightly bumps in the carpet so thinking about running all wires in the grooves and under the crossmember etc. I would tape over them and then add the soundproofing so should be secure. I could even go under the car if easier but that doesn't seem necessary and introduces an increase risk of failure/damage.
Is there any recommended routing please?
20240309_134231.jpg 64.68K 6 downloads
