Hi,
I have just put my engine back together and I wondering if the cam timing has not been set correctly, seem to run out of steam at about 5,000 revs.
Also seems to be a lot of fumes / vapour coming out of the transfer case breather which it didn’t before. Same block / pistons / head as before taking apart due to oil leaks. So replaced the cam during re-build with MED belt drive.
I’m thinking the timing needs advancing, what your thoughts,
1310 A+
MED RS Cam Shaft 1250 - 6500
Twin 1 1/2 HS4
