Hi. anybody had issues with indicator. New indicators, new wiring loom. basically everything new. mk1 mini. can hear 1 click on the relay when I move the stalk up. but thats it. horn works ok,
any ideas
Best Answer Rusty Mike , 20 March 2024 - 02:25 PM
Hi Thanks for the replies.
I double checked the wiring on the front indicators. I put the wires the wrong way round on the NS front. ( idiot) so now ok.
Go to the full post
Posted 17 March 2024 - 06:02 PM
any ideas
Posted 17 March 2024 - 06:42 PM
Do the external lights come on when you operate the column switch ?.
Posted 18 March 2024 - 09:42 AM
sorry not sure what you mean. The lights work on the light switch. and the main beam works on the floor switch.
does the body of the flasher relay need to be earthed?
Posted 18 March 2024 - 10:06 AM
I'm assuming he meant do the indicator lamps light up on the outside of the car when it does that one click
is the colulmn switch / stalk still original, they can get gunked up and not provide a good connection
are the lamps still standard or have you fitted LED's
no I don't think the body needs earth/ground
Edited by stuart bowes, 18 March 2024 - 10:08 AM.
Posted 20 March 2024 - 02:25 PM Best Answer
Posted 21 March 2024 - 01:34 PM
Posted 22 March 2024 - 07:22 PM
no, the old light headlight where ok, so I used them. and kept the indicators original
Posted 22 March 2024 - 07:43 PM
Posted 28 March 2024 - 12:32 PM
yeh must be when theres just 1 out
Posted 28 March 2024 - 01:57 PM
Indicator flashers are supposed to be failsafe - the contacts start closed so they should at least light. If there are bulbs out then they should flash slowly, or not all all (sometimes the loose blown filament shorts the bulb though). If there's a short more current will generate heat more quickly in the bimetallic flashing thing 'n they'll go in to disco mode.
